REST API reference
Retrieve a multi-admin-verify configuration
Retrieves the multi-admin-verify configuration to review the current settings related to administrative verification processes.
HTTP method and endpoint
GET /security/multi-admin-verify
Introduced in
ONTAP 9.11
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
approval_expiry
string
Default time for requests to be approved, in ISO-8601 duration format.
approval_groups
array[string]
List of approval groups that are allowed to approve requests for rules that don't have approval groups.
enabled
boolean
execution_expiry
string
Default time for requests to be executed once approved, in ISO-8601 duration format.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
  "approval_expiry": "string",
  "approval_groups": [
    "string"
  "execution_expiry": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
