Retrieve a multi-admin-verify configuration
GET /security/multi-admin-verify
Introduced In: 9.11
Retrieves the multi-admin-verify configuration.
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
approval_expiry |
string |
Default time for requests to be approved, in ISO-8601 duration format. |
approval_groups |
array[string] |
List of approval groups that are allowed to approve requests for rules that don't have approval groups. |
enabled |
boolean |
execution_expiry |
string |
Default time for requests to be executed once approved, in ISO-8601 duration format. |
required_approvers |
integer |
The number of required approvers, excluding the user that made the request. |
"approval_expiry": "string",
"approval_groups": [
"string"
"execution_expiry": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
