Retrieve attributes of the origin of a FlexCache volume in the cluster
Retrieves attributes of a FlexCache volume's origin in the cluster. This information helps you understand the configuration and status of the FlexCache origins for efficient management.
HTTP method and endpoint
GET /storage/flexcache/origins/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves attributes of the origin of a FlexCache in the cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are included by default in GET results. The recommended method to use this API is to filter and retrieve only the required fields. See Requesting specific fields to learn more.
flexcaches.ip_address- IP address of FlexCache. -
flexcaches.size- Physical size of FlexCache. -
flexcaches.guarantee.type- Space guarantee style of FlexCache. -
flexcaches.state- State of FlexCache. -
flexcaches.dr_cache- True if the cache is a DR cache.
Related ONTAP commands
volume flexcache origin show-caches
Learn more
uuid |
string |
path |
True |
Unique identifier of origin of FlexCache. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
block_level_invalidation |
boolean |
Block level invalidation enables the FlexCache volume to retain blocks that are not changed at the FlexCache volume without having to evict them. This means that the FlexCache volume does not have to again incur the computational cost of fetching blocks over the WAN from the FlexCache volume origin on the next client access. Block level invalidation is a property of the origin volume. Without block level invalidation, any write at the origin volume would evict the whole file at the FlexCache volume, since by default, origin volume does a file level invalidation. |
flexcaches |
array[flexcache_relationship] |
global_file_locking_enabled |
boolean |
Specifies whether a global file locking option is enabled for an origin volume of a FlexCache volume. |
name |
string |
Origin volume name |
svm |
Origin volume SVM |
uuid |
string |
Origin volume UUID. Unique identifier for origin of FlexCache. |
"href": "/api/resourcelink"
"flexcaches": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04 15:00:00 -0400",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"name": "vol1, vol_2",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
svm
Origin volume SVM
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
