REST API reference
Retrieve attributes of the origin of a FlexCache volume in the cluster
Retrieves attributes of a FlexCache volume's origin in the cluster. This information helps you understand the configuration and status of the FlexCache origins for efficient management.
HTTP method and endpoint
GET /storage/flexcache/origins/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves attributes of the origin of a FlexCache in the cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are included by default in GET results. The recommended method to use this API is to filter and retrieve only the required fields. See Requesting specific fields to learn more.
  • flexcaches.ip_address - IP address of FlexCache.
  • flexcaches.size - Physical size of FlexCache.
  • flexcaches.guarantee.type - Space guarantee style of FlexCache.
  • flexcaches.state - State of FlexCache.
  • flexcaches.dr_cache - True if the cache is a DR cache.
  • volume flexcache origin show-caches
uuid
string
path
True
Unique identifier of origin of FlexCache.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
block_level_invalidation
boolean
Block level invalidation enables the FlexCache volume to retain blocks that are not changed at the FlexCache volume without having to evict them. This means that the FlexCache volume does not have to again incur the computational cost of fetching blocks over the WAN from the FlexCache volume origin on the next client access. Block level invalidation is a property of the origin volume. Without block level invalidation, any write at the origin volume would evict the whole file at the FlexCache volume, since by default, origin volume does a file level invalidation.
flexcaches
array[flexcache_relationship]
global_file_locking_enabled
boolean
Specifies whether a global file locking option is enabled for an origin volume of a FlexCache volume.
name
string
Origin volume name
svm
svm
Origin volume SVM
uuid
string
Origin volume UUID. Unique identifier for origin of FlexCache.
      "href": "/api/resourcelink"
  "flexcaches": [
      "cluster": {
        "name": "cluster1",
      "create_time": "2018-06-04 19:00:00 +0000",
      "ip_address": "10.10.10.7",
      "size": 0,
      "state": "string",
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
  "name": "vol1, vol_2",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cluster
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster management IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
svm
svm
volume
volume
svm
Origin volume SVM
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
