Retrieve QoS options
Retrieves quality of service (QoS) options to view available settings for managing performance levels.
HTTP method and endpoint
GET /storage/qos/qos-options
Introduced in
ONTAP 9.14
Usage notes
Retrieves QoS options.
Related ONTAP commands
qos settings cluster-options show
background_task_reserve |
integer |
query |
False |
Filter by background_task_reserve |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
integer |
Percentage reserve for critical background tasks. |
"href": "/api/resourcelink"
"background_task_reserve": 33
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
