REST API reference
Retrieve QoS options
Accesses QoS options to view the current configuration settings available for quality of service management within your storage environment.
HTTP method and endpoint
GET /storage/qos/qos-options
Introduced in
ONTAP 9.14
Usage notes
Retrieves QoS options. This option is available only at diagnostic privilege level and above.
  • qos settings cluster-options show
background_task_reserve
integer
query
False
Filter by background_task_reserve
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
integer
Percentage reserve for critical background tasks.
      "href": "/api/resourcelink"
  "background_task_reserve": 33
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
