REST API reference
Retrieve qtrees
Retrieves qtrees configured for FlexVol or FlexGroup volumes. Use this endpoint to access qtree information for storage management and optimization, especially when you need specific qtree properties for detailed analysis.
HTTP method and endpoint
GET /storage/qtrees
Introduced in
ONTAP 9.6
Usage notes
Retrieves qtrees configured for all FlexVol volumes or FlexGroup volumes.
Use the fields query parameter to retrieve all properties of the qtree. If the fields query parameter is not used, then GET returns the qtree name and qtree id only.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • statistics.*
  • qtree show
id
integer
query
False
Filter by id
  • Max value: 4994
  • Min value: 0
path
string
query
False
Filter by path
export_policy.id
integer
query
False
Filter by export_policy.id
export_policy.name
string
query
False
Filter by export_policy.name
name
string
query
False
Filter by name
user.id
string
query
False
Filter by user.id
  • Introduced in: 9.9
user.name
string
query
False
Filter by user.name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
security_style
string
query
False
Filter by security_style
group.name
string
query
False
Filter by group.name
group.id
string
query
False
Filter by group.id
nas.path
string
query
False
Filter by nas.path
unix_permissions
integer
query
False
Filter by unix_permissions
_tags
string
query
False
Filter by _tags
  • Introduced in: 9.13
statistics.status
string
query
False
Filter by statistics.status
  • Introduced in: 9.8
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.other
integer
query
False
Filter by statistics.throughput_raw.other
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
qos_policy.uuid
string
query
False
Filter by qos_policy.uuid
qos_policy.max_throughput_mbps
integer
query
False
Filter by qos_policy.max_throughput_mbps
  • Max value: 4194303
  • Min value: 0
qos_policy.name
string
query
False
Filter by qos_policy.name
qos_policy.max_throughput_iops
integer
query
False
Filter by qos_policy.max_throughput_iops
  • Max value: 2147483647
  • Min value: 0
qos_policy.min_throughput_iops
integer
query
False
Filter by qos_policy.min_throughput_iops
  • Min value: 0
qos_policy.min_throughput_mbps
integer
query
False
Filter by qos_policy.min_throughput_mbps
  • Min value: 0
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[qtree]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "_tags": [
        "team:csi",
        "environment:test"
      "export_policy": {
        "id": 100,
        "name": "default"
      "group": {
        "id": "20001",
        "name": "unix_group1"
      "id": 1,
      "name": "string",
      "nas": {
        "path": "/volume3/qtree1"
      "path": "/volume3/qtree1",
      "qos_policy": {
        "max_throughput_iops": 10000,
        "max_throughput_mbps": 500,
        "min_throughput_iops": 2000,
        "min_throughput_mbps": 500,
        "name": "performance",
      "security_style": "string",
      "statistics": {
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25 06:20:13 -0500"
      "svm": {
        "name": "svm1",
      "unix_permissions": 493,
      "user": {
        "id": "10001",
        "name": "unix_user1"
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
918235
A volume with UUID was not found.
2621462
The specified SVM does not exist.
5242889
Failed to get the qtree from volume.
5242956
Failed to obtain qtree.
5242965
Invalid qtree path. The volume name component of the qtree path, must be the same as the volume specified with the parameter.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_policy
Export Policy
_links
_links
id
integer
name
string
group
The user set as owner of the qtree.
id
string
The numeric ID of the group that owns the qtree. Valid in POST or PATCH.
name
string
Alphanumeric group name of group that owns the qtree. Valid in POST or PATCH.
nas
path
string
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH.
qos_policy
When "min_throughput_iops", "min_throughput_mbps", "max_throughput_iops" or "max_throughput_mbps" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
_links
_links
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled with the next closest collection and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes does not have the latest data.
throughput_raw
throughput_raw
timestamp
string
The timestamp of the performance data.
svm
Required in POST
_links
_links
name
string
uuid
string
user
id
string
The numeric ID of the user who owns the qtree. Valid in POST or PATCH.
name
string
Alphanumeric username of user who owns the qtree. Valid in POST or PATCH.
volume
Required in POST
_links
_links
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_links
_links
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
export_policy
export_policy
Export Policy
group
group
id
integer
The identifier for the qtree, unique within the qtree's volume.
name
string
The name of the qtree. Required in POST; optional in PATCH.
nas
nas
path
string
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. This field is to be deprecated and replaced with nas.path.
qos_policy
qos_policy
security_style
string
Security style. Valid in POST or PATCH.
statistics
statistics
svm
svm
Required in POST
unix_permissions
integer
The UNIX permissions for the qtree. Valid in POST or PATCH.
user
user
volume
volume
Required in POST
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
