Retrieve qtrees
Retrieves information about qtrees configured for all FlexVol or FlexGroup volumes. Use this endpoint to access detailed qtree properties by specifying the fields query parameter as needed.
HTTP method and endpoint
GET /storage/qtrees
Introduced in
ONTAP 9.6
Usage notes
Retrieves qtrees configured for all FlexVol volumes or FlexGroup volumes.
Use the fields query parameter to retrieve all properties of the qtree. If the fields query parameter is not used, then GET returns the qtree name and qtree id only.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
statistics.*
Related ONTAP commands
qtree show
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
unix_permissions |
integer |
query |
False |
Filter by unix_permissions |
user.id |
string |
query |
False |
Filter by user.id
user.name |
string |
query |
False |
Filter by user.name
statistics.iops_raw.total |
integer |
query |
False |
Filter by statistics.iops_raw.total
statistics.iops_raw.other |
integer |
query |
False |
Filter by statistics.iops_raw.other
statistics.iops_raw.read |
integer |
query |
False |
Filter by statistics.iops_raw.read
statistics.iops_raw.write |
integer |
query |
False |
Filter by statistics.iops_raw.write
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total
statistics.throughput_raw.other |
integer |
query |
False |
Filter by statistics.throughput_raw.other
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write
statistics.status |
string |
query |
False |
Filter by statistics.status
nas.path |
string |
query |
False |
Filter by nas.path
export_policy.name |
string |
query |
False |
Filter by export_policy.name |
export_policy.id |
integer |
query |
False |
Filter by export_policy.id |
id |
integer |
query |
False |
Filter by id |
volume.name |
string |
query |
False |
Filter by volume.name |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
security_style |
string |
query |
False |
Filter by security_style |
name |
string |
query |
False |
Filter by name |
path |
string |
query |
False |
Filter by path |
qos_policy.max_throughput_mbps |
integer |
query |
False |
Filter by qos_policy.max_throughput_mbps
qos_policy.max_throughput_iops |
integer |
query |
False |
Filter by qos_policy.max_throughput_iops
qos_policy.name |
string |
query |
False |
Filter by qos_policy.name
qos_policy.min_throughput_iops |
integer |
query |
False |
Filter by qos_policy.min_throughput_iops
qos_policy.uuid |
string |
query |
False |
Filter by qos_policy.uuid
group.id |
string |
query |
False |
Filter by group.id
group.name |
string |
query |
False |
Filter by group.name
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[qtree] |
"next": {
"href": "/api/resourcelink"
"records": [
"export_policy": {
"id": "100",
"name": "default"
"group": {
"id": "20001",
"name": "unix_group1"
"id": "1",
"name": "string",
"nas": {
"path": "/volume3/qtree1"
"path": "/volume3/qtree1",
"qos_policy": {
"max_throughput_iops": "10000",
"max_throughput_mbps": "500",
"min_throughput_iops": "2000",
"name": "performance",
"security_style": "string",
"statistics": {
"iops_raw": {
"read": "200",
"total": "1000",
"write": "100"
"status": "ok",
"throughput_raw": {
"read": "200",
"total": "1000",
"write": "100"
"timestamp": "2017-01-25T11:20:13Z"
"svm": {
"name": "svm1",
"unix_permissions": "0755",
"user": {
"id": "10001",
"name": "unix_user1"
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_policy
Export Policy
_links |
id |
integer |
name |
string |
group
The user set as owner of the qtree.
id |
string |
The numeric ID of the group that owns the qtree. Valid in POST or PATCH. |
name |
string |
Alphanumeric group name of group that owns the qtree. Valid in POST or PATCH. |
nas
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. |
qos_policy
When "min_throughput_iops", "max_throughput_iops" or "max_throughput_mbps" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
_links |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled with the next closest collection and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes does not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
The timestamp of the performance data. |
svm
Required in POST
_links |
name |
string |
The name of the SVM. |
uuid |
string |
user
id |
string |
The numeric ID of the user who owns the qtree. Valid in POST or PATCH. |
name |
string |
Alphanumeric username of user who owns the qtree. Valid in POST or PATCH. |
volume
Required in POST
_links |
name |
string |
The name of the volume. |
uuid |
string |
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_links |
export_policy |
Export Policy |
group |
The user set as owner of the qtree. |
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. Required in POST; optional in PATCH. |
nas |
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. This field is to be deprecated and replaced with nas.path. |
qos_policy |
When "min_throughput_iops", "max_throughput_iops" or "max_throughput_mbps" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed. |
security_style |
string |
Security style. Valid in POST or PATCH. |
statistics |
These are raw IOPS and throughput performance numbers. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. |
svm |
Required in POST |
unix_permissions |
integer |
The UNIX permissions for the qtree. Valid in POST or PATCH. |
user |
volume |
Required in POST |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
