REST API reference
Retrieve attributes for an EBR operation
Retrieves a list of attributes for an EBR operation, providing the necessary details for managing event-based retention.
HTTP method and endpoint
GET /storage/snaplock/event-retention/operations/{id}
Introduced in
ONTAP 9.7
  • snaplock event-retention show
id
string
path
True
Unique identifier of an EBR operation
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
id
integer
Operation ID
num_files_failed
integer
Specifies the number of files on which the application of EBR policy failed.
num_files_processed
integer
Specifies the number of files on which EBR policy was applied successfully.
num_files_skipped
integer
Specifies the number of files on which the application of EBR policy was skipped.
num_inodes_ignored
integer
Specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files.
path
string
The path for the EBR operation. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.
policy
policy
state
string
Specifies the operation status of an EBR operation.
svm
svm
volume
volume
      "href": "/api/resourcelink"
  "id": 16842759,
  "num_files_failed": 0,
  "num_files_processed": 50,
  "num_files_skipped": 2,
  "num_inodes_ignored": 2,
  "path": "/dir1/file",
  "policy": {
    "name": "string",
    "retention_period": "P30M"
  "state": "completed",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090242
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
policy
_links
_links
name
string
Specifies the EBR policy name
retention_period
string
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the strings "infinite" and "unspecified".
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
