Retrieve attributes for an EBR operation
GET /storage/snaplock/event-retention/operations/{id}
Introduced In: 9.7
Retrieves a list of attributes for an EBR operation.
Related ONTAP commands
snaplock event-retention show
Name | Type | In | Required | Description |
id |
string |
path |
True |
Unique identifier of an EBR operation |
fields |
array[string] |
query |
False |
Status: 200, Ok
Name | Type | Description |
_links |
id |
integer |
Operation ID |
num_files_failed |
integer |
Specifies the number of files on which the application of EBR policy failed. |
num_files_processed |
integer |
Specifies the number of files on which EBR policy was applied successfully. |
num_files_skipped |
integer |
Specifies the number of files on which the application of EBR policy was skipped. |
num_inodes_ignored |
integer |
Specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files. |
path |
string |
The path for the EBR operation. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory. |
policy |
state |
string |
Specifies the operation status of an EBR operation. |
svm |
volume |
"href": "/api/resourcelink"
"id": 16842759,
"num_files_failed": 0,
"num_files_processed": 50,
"num_files_skipped": 2,
"num_inodes_ignored": 2,
"path": "/dir1/file",
"policy": {
"name": "string",
"retention_period": "P30M"
"state": "completed",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response codes
Error code | Description |
14090242 |
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
policy
_links |
name |
string |
Specifies the EBR policy name |
retention_period |
string |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
