REST API reference
Retrieve attributes of an EBR policy
Retrieves the attributes of a specified Event Based Retention (EBR) policy to understand its configuration and settings.
HTTP method and endpoint
GET /storage/snaplock/event-retention/policies/{policy.name}
Introduced in
ONTAP 9.7
Usage notes
Retrieves a list of attributes of the specified Event Based Retention (EBR) policy.
  • snaplock event-retention policy show
policy.name
string
path
True
Name of the retention policy
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
name
string
Specifies the EBR policy name
retention_period
string
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the strings "infinite" and "unspecified".
svm
svm
      "href": "/api/resourcelink"
  "name": "string",
  "retention_period": "P30M",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response codes
Error code Description
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
