Retrieve attributes of an EBR policy
GET /storage/snaplock/event-retention/policies/{policy.name}
Retrieves a list of attributes of the specified Event Based Retention (EBR) policy.
Related ONTAP commands
snaplock event-retention policy show
policy.name  |
string  |
path  |
True  |
Name of the retention policy  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
name  |
string  |
Specifies the EBR policy name  |
retention_period  |
string  |
Specifies the retention period of an EBR policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P  |
svm  |
      "href": "/api/resourcelink"
  "name": "string",
  "retention_period": "P30M",
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
