Retrieve SNMP user details
Retrieves details about an SNMP user, which helps you manage SNMP configurations across different SVMs or remote switches.
HTTP method and endpoint
GET /support/snmp/users/{engine_id}/{name}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the details of an SNMP user. The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
Related ONTAP commands
security snmpusers -vserver <SVM Name> -username <User Name> -
security login show -application snmp -vserver <SVM Name> -user-or-group-name <User Name>
Learn more
engine_id |
string |
path |
True |
Engine ID of owning SVM or remote switch. |
name |
string |
path |
True |
SNMP user name. |
fields |
array[string] |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
authentication_method |
string |
Optional authentication method. |
comment |
string |
Optional comment text. |
engine_id |
string |
Optional SNMPv3 engine identifier. For a local SNMP user belonging to the administrative Storage Virtual Machine (SVM), the default value of this parameter is the SNMPv3 engine identifier for the administrative SVM. For a local SNMP user belonging to a data SVM, the default value of this parameter is the SNMPv3 engine identifier for that data SVM. For an SNMPv1/SNMPv2c community, this parameter should not be specified in "POST" method. For a remote switch SNMPv3 user, this parameter specifies the SNMPv3 engine identifier for the remote switch. This parameter can also optionally specify a custom engine identifier. |
name |
string |
SNMP user name. |
owner |
Optional name and UUID of owning Storage Virtual Machine (SVM). |
scope |
string |
Set to "svm" for data Storage Virtual Machine (SVM) SNMP users and to "cluster" for administrative SVM SNMP users. |
snmpv3 |
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user. |
switch_address |
string |
Optional remote switch address. It can be an IPv4 address or an IPv6 address. A remote switch can be queried over SNMPv3 using ONTAP SNMP client functionality. Querying such a switch requires an SNMPv3 user (remote switch user) to be configured on the switch. Since ONTAP requires remote switch user's SNMPv3 credentials (to query it), this user must be configured in ONTAP as well. This parameter is specified when configuring such a user.
"href": "/api/resourcelink"
"authentication_method": "usm",
"comment": "This is a comment.",
"engine_id": "80000315055415ab26d4aae811ac4d005056bb792e",
"name": "snmpv3user2",
"owner": {
"name": "svm1",
"scope": "svm",
"snmpv3": {
"authentication_protocol": "sha2_256",
"privacy_protocol": "aes128"
"switch_address": "10.23.34.45"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
owner
_links |
name |
string |
uuid |
string |
snmpv3
_links |
authentication_protocol |
string |
Authentication protocol. |
privacy_protocol |
string |
Privacy protocol. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
