REST API reference
Retrieve SNMP user details
GET /support/snmp/users/{engine_id}/{name}
Introduced In: 9.7
Retrieves the details of an SNMP user. The engine ID can be the engine ID of the administrative SVM or a data SVM. It can also be the SNMPv3 engine ID of a remote switch.
  • security snmpusers -vserver <SVM Name> -username <User Name>
  • security login show -application snmp -vserver <SVM Name> -user-or-group-name <User Name>
engine_id
string
path
True
Engine ID of owning SVM or remote switch.
name
string
path
True
SNMP user name.
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
_links
_links
authentication_method
string
Optional authentication method.
comment
string
Optional comment text.
engine_id
string
Optional SNMPv3 engine identifier. For a local SNMP user belonging to the administrative Storage Virtual Machine (SVM), the default value of this parameter is the SNMPv3 engine identifier for the administrative SVM. For a local SNMP user belonging to a data SVM, the default value of this parameter is the SNMPv3 engine identifier for that data SVM. For an SNMPv1/SNMPv2c community, this parameter should not be specified in "POST" method. For a remote switch SNMPv3 user, this parameter specifies the SNMPv3 engine identifier for the remote switch. This parameter can also optionally specify a custom engine identifier.
name
string
SNMP user name.
owner
owner
Optional name and UUID of owning Storage Virtual Machine (SVM).
scope
string
Set to "svm" for data Storage Virtual Machine (SVM) SNMP users and to "cluster" for administrative SVM SNMP users.
snmpv3
snmpv3
Optional parameter that can be specified only for an SNMPv3 user i.e. when 'authentication_method' is either 'usm' or 'both'. This parameter defines the SNMPv3 credentials for an SNMPv3 user.
switch_address
string
Optional remote switch address. It can be an IPv4 address or an IPv6 address. A remote switch can be queried over SNMPv3 using ONTAP SNMP client functionality. Querying such a switch requires an SNMPv3 user (remote switch user) to be configured on the switch. Since ONTAP requires remote switch user's SNMPv3 credentials (to query it), this user must be configured in ONTAP as well. This parameter is specified when configuring such a user.
  • example: 10.23.34.45
  • Introduced in: 9.7
  • readCreate: 1
  • x-nullable: true
      "href": "/api/resourcelink"
  "authentication_method": "usm",
  "comment": "This is a comment.",
  "engine_id": "80000315055415ab26d4aae811ac4d005056bb792e",
  "name": "snmpv3user2",
  "owner": {
    "name": "svm1",
  "scope": "svm",
  "snmpv3": {
    "authentication_protocol": "sha2_256",
    "privacy_protocol": "aes128"
  "switch_address": "10.23.34.45"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
owner
_links
_links
name
string
uuid
string
snmpv3
_links
_links
string
Authentication protocol.
privacy_protocol
string
Privacy protocol.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
