Manage QoS options
Configure Quality of Service (QoS) options to optimize and manage performance levels across your ONTAP system. Use these endpoints to retrieve and modify QoS settings, ensuring consistent application performance.
Quality of Service Options
A QoS option represents a configuration detail that is used by QoS.
Retrieving a QoS option from the cluster
The following example retrieves the QoS option in the cluster.
curl -X GET "https://<mgmt-ip>/api/storage/qos/qos-options?return_timeout=0" -H "accept: application/json" -H "Content-Type: application/json"
2) Update a QoS option
The following example shows how to modify the background task reserve policy to 40%.
curl -X PATCH "https://<mgmt-ip>/api/storage/qos/qos-options?return_timeout=0" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"background_task_reserve\": 40 }"
