REST API reference
Manage QoS options
Configure and manage Quality of Service (QoS) options to optimize performance settings in your ONTAP environment. Use these endpoints to retrieve and update specific QoS configurations as needed.
Quality of Service Options
A QoS option represents a configuration detail that is used by QoS.
Retrieving a QoS option from the cluster
The following example retrieves the QoS option in the cluster.
curl -X GET "https://<mgmt-ip>/api/storage/qos/qos-options?return_timeout=0" -H "accept: application/json" -H "Content-Type: application/json"
2) Update a QoS option
The following example shows how to modify the background task reserve policy to 40%.
curl -X PATCH "https://<mgmt-ip>/api/storage/qos/qos-options?return_timeout=0" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"background_task_reserve\": 40 }"
