REST API reference
Manage S3 service bucket configuration
Configure and manage S3 service buckets to organize and control access to your object data. Utilize these endpoints to handle object storage policies, encryption settings, and lifecycle rules for efficient data management within your S3 environment.
Overview
An S3 bucket is a container of objects. Each bucket defines an object namespace. S3 server requests specify objects using a bucket-name and object-name pair. An object consists of data, along with optional metadata and access controls, accessible via a name. An object resides within a bucket. There can be more than one bucket in an S3 server. Buckets which are created for the server are associated with an S3 user that is created on the S3 server. An access policy is an object that when associated with a resource, defines their permissions. Buckets and objects are defined as resources. By default, only the "root" user can access these resources. Access policies are used to manage access to these resources by enabling ONTAP admin to provide "grants" to allow other users to perform operations on the buckets.
Retrieving all fields for all S3 buckets of an SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/buckets
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets?fields=**&return_records=true" -H "accept: application/json"
# The response:
"records": [
    "svm": {
      "uuid": "12f3ba4c-7ae0-11e9-8c06-0050568ea123",
      "name": "vs1"
    "uuid": "527812ab-7c6d-11e9-97e8-0050568ea123",
    "name": "bucket-2",
    "volume": {
      "name": "fg_oss_1558514455",
      "uuid": "51276f5f-7c6d-11e9-97e8-0050568ea123"
    "size": 209715200,
    "logical_used_size": 157286400,
    "encryption": {
      "enabled": false
    "comment": "S3 bucket.",
    "qos_policy": {
      "min_throughput_iops": 0,
      "min_throughput_mbps": 0,
      "max_throughput_iops": 1000,
      "max_throughput_mbps": 50,
      "uuid": "39ac471f-ff35-11e9-b0f9-005056a7ab52",
      "name": "vs0_auto_gen_policy_39a9522f_ff35_11e9_b0f9_005056a7ab52"
    "audit_event_selector": {
      "access":"all",
      "permission":"all"
    "versioning-state": "disabled"
    "svm": {
      "name": "vs1"
    "uuid": "a8234aec-7e06-11e9-97e8-0050568ea123",
    "name": "bucket-1",
    "volume": {
      "name": "fg_oss_1558690256",
      "uuid": "a36a1ea7-7e06-11e9-97e8-0050568ea123"
    "size": 1677721600,
    "logical_used_size": 0,
    "encryption": {
      "enabled": false
    "comment": "bucket1",
    "qos_policy": {
    "policy": {
      "statements": [
          "effect": "allow",
          "actions": [
          "principals": [
            "Alice"
          "resources": [
          "sid": "fullAccessForAliceToBucket"
          "effect": "allow",
          "actions": [
            "ListBucket",
            "GetObject"
          "principals": [
            "ann",
            "jack"
          "resources": [
            "bucket-1",
            "bucket-1/*"
          "sid": "AccessToListAndGetObjectForAnnAndJack",
          "conditions": [
              "operator": "ip_address",
              "source_ips": [
                "1.1.1.1/10"
              "operator": "string_equals",
              "prefixes": [
                "pref1",
                "pref2"
              "usernames": [
                "user1",
                "user2"
              "delimiters": [
                "del1",
                "del2"
              "operator": "numeric_equals",
              "max_keys": [
                100
          "effect": "deny",
          "actions": [
            "*Object"
          "principals": [
            "mike",
            "group/group1",
            "nasgroup/group2",
          "resources": [
            "bucket-1/policy-docs/*",
            "bucket-1/confidential-*"
          "sid": "DenyAccessToGetPutDeleteObjectForMike"
          "effect": "allow",
          "actions": [
            "GetObject"
          "principals": [
          "resources": [
            "bucket-1/readme"
          "sid": "AccessToGetObjectForAnonymousUsers"
          "effect": "allow",
          "actions": [
            "GetObject"
          "principals": [
          "resources": [
            "bucket-1/policies/examples/*"
          "sid": "AccessToGetObjectForAllUsersOfSVM"
"num_records": 2
Retrieving the specified bucket associated with an SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/buckets/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/527812ab-7c6d-11e9-97e8-0050568ea123" -H "accept: application/json"
# The response:
"svm": {
  "name": "vs1"
"name": "bucket-2",
"volume": {
"size": 209715200,
"encryption": {
  "enabled": false
"qos_policy": {
  "max_throughput_mbps": 0,
Creating an S3 bucket for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-3\"}"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 24 May 2019 11:22:14 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/?name=bucket-3
Content-Length: 353
"num_records": 1,
"records": [
    "name": "bucket-3",
"job": {
  "uuid": "2e880171-7e16-11e9-bfdc-0050568ea123",
      "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea123"
Creating an S3 bucket along with QoS policies and event selector for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/services/3e538980-f0af-11e9-ba68-0050568e9798/buckets?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 bucket.\", \"name\": \"bucket-3\", \"qos_policy\": { \"min_throughput_iops\": 0, \"min_throughput_mbps\": 0, \"max_throughput_iops\": 1000000, \"max_throughput_mbps\": 900000, \"uuid\": \"02d07a93-6177-11ea-b241-000c293feac8\", \"name\": \"vs0_auto_gen_policy_02cfa02a_6177_11ea_b241_000c293feac8\" },  \"audit_event_selector\": { \"access\": \"all\", \"permission\": \"all\"}}"
# The response:
Content-Length: 353
"num_records": 1,
"records": [
    "name": "bucket-3",
"job": {
Creating an S3 bucket along with policies for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/services/3e538980-f0af-11e9-ba68-0050568e9798/buckets?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-3\", \"policy\": { \"statements\": [ { \"actions\": [ \"GetObject\" ], \"conditions\": [ { \"operator\": \"ip_address\", \"source_ips\": [ \"1.1.1.1/23\", \"1.2.2.2/20\" ] }, { \"max_keys\": [ 1000 ], \"operator\": \"numeric_equals\" }, { \"delimiters\": [ \"/\" ], \"operator\": \"string_equals\", \"prefixes\": [ \"pref\" ], \"usernames\": [ \"user1\" ] } ], \"effect\": \"allow\", \"resources\": [ \"bucket-3/policies/examples/*\" ], \"sid\": \"AccessToGetObjectForAllUsersofSVM\" }, { \"actions\": [ \"*Object\" ], \"effect\": \"deny\", \"principals\": [ \"mike\", \"group/grp1\" ], \"resources\": [ \"bucket-3/policy-docs/*\", \"bucket-3/confidential-*\" ], \"sid\": \"DenyAccessToObjectForMike\" }, { \"actions\": [ \"GetObject\" ], \"effect\": \"allow\", \"principals\": [ \"*\" ], \"resources\": [ \"bucket-3/readme\" ], \"sid\": \"AnonnymousAccessToGetObjectForUsers\" } ] } }"
# The response:
Content-Length: 353
"num_records": 1,
"records": [
    "name": "bucket-3",
"job": {
Creating an S3 bucket along with lifecycle management rules
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/services/3e538980-f0af-11e9-ba68-0050568e9798/buckets?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-4\", \"lifecycle_management\": { \"rules\": [ { \"name\": \"rule1\", \"expiration\": { \"object_age_days\" : \"1000\" } , \"abort_incomplete_multipart_upload\" : { \"after_initiaion_days\" : 200 } , \"object_filter\": { \"prefix\" : \"obj1*/\" ,  \"size_greater_than\" : \"1000\" } }, { \"name\": \"rule2\", \"object_filter\": { \"size_greater_than\" : \"50\" }, \"expiration\": { \"object_age_days\" : \"5000\" } } ] } }"
# The response:
Date: Fri, 18 April 2022 11:22:14 GMT
Location: /api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/?name=bucket-4
Content-Length: 363
"num_records": 1,
"records": [
    "name": "bucket-4",
"job": {
Creating an S3 bucket with object locking enabled for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea143/buckets?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea143\" } ], \"comment\": \"S3 Compliance mode bucket.\", \"constituents_per_aggregate\": 4, \"name\": \"bucket-5\", \"retention\": { \"mode\": \"compliance\", \"default_period\" : \"P1Y\" } }"
# The response:
Date: Fri, 24 May 2023 11:25:14 GMT
Location: /api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea143/buckets/?name=bucket-5
Content-Length: 353
"num_records": 1,
"records": [
    "name": "bucket-5",
    "comment": "S3 Compliance mode bucket."
"job": {
  "uuid": "2e880171-7e16-11e9-bfdc-0050568ea143",
      "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea143"
Updating an S3 bucket for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/754389d0-7e13-11e9-bfdc-0050568ea122" -H "accept: application/json?return_records=true" -H "Content-Type: application/json" -d "{ \"comment\": \"Bucket modified.\", \"size\": 111111111111,  \"qos_policy\": { \"min_throughput_iops\": 0, \"min_throughput_mbps\": 0, \"max_throughput_iops\": 1000000, \"max_throughput_mbps\": 900000, \"uuid\": \"02d07a93-6177-11ea-b241-000c293feac8\", \"name\": \"vs0_auto_gen_policy_02cfa02a_6177_11ea_b241_000c293feac8\"}}"
# The response:
Date: Fri, 24 May 2019 11:32:27 GMT
Content-Length: 189
"job": {
  "uuid": "9beafabb-7e17-11e9-bfdc-0050568ea123",
      "href": "/api/cluster/jobs/9beafabb-7e17-11e9-bfdc-0050568ea123"
Updating an S3 bucket policy and event selector for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/3e538980-f0af-11e9-ba68-0050568e9798/buckets/754389d0-7e13-11e9-bfdc-0050568ea122?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"policy\": { \"statements\": [ { \"actions\": [ \"*\" ], \"conditions\": [ { \"operator\": \"ip_address\", \"source_ips\": [ \"1.1.1.1/23\", \"1.2.2.2/20\" ] }, { \"max_keys\": [ 1000 ], \"operator\": \"numeric_equals\" }, { \"delimiters\": [ \"/\" ], \"operator\": \"string_equals\", \"prefixes\": [ \"pref\" ], \"usernames\": [ \"user1\" ] } ], \"effect\": \"allow\", \"resources\": [ \"*\" ], \"sid\": \"fullAccessForAllPrincipalsToBucket\"} ] }, \"audit_event_selector\": { \"access\": \"read\", \"permission\": \"deny\"} }"
# The response:
Content-Length: 189
"job": {
Updating the default-retention period on an S3 bucket for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/3e538980-f0af-11e9-ba68-0050568e9798/buckets/754389d0-7e13-11e9-bfdc-0050568ea122?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"retention\": { \"default_period\" : \"P10Y\" } }"
# The response:
Date: Fri, 24 May 2023 11:35:27 GMT
Content-Length: 189
"job": {
  "uuid": "9beafabb-7e17-11e9-bfdc-0050568ea143",
      "href": "/api/cluster/jobs/9beafabb-7e17-11e9-bfdc-0050568ea143"
Deleting an S3 bucket policy for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/3e538980-f0af-11e9-ba68-0050568e9798/buckets/754389d0-7e13-11e9-bfdc-0050568ea122?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"policy\": { \"statements\": [ ] } }"
# The response:
Content-Length: 189
"job": {
Deleting an S3 bucket for a specified SVM
# The API:
# The call:
curl -iku admin:netapp1! -X DELETE "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/754389d0-7e13-11e9-bfdc-0050568ea123?return_records=true" -H "accept: application/json"
# The response:
Date: Fri, 24 May 2019 11:40:17 GMT
Content-Length: 189
"job": {
  "uuid": "b3af4a54-7e18-11e9-bfdc-0050568ea123",
      "href": "/api/cluster/jobs/b3af4a54-7e18-11e9-bfdc-0050568ea123"
