REST API reference
Manage S3 service bucket configuration
Overview
An S3 bucket is a container of objects. Each bucket defines an object namespace. S3 server requests specify objects using a bucket-name and object-name pair. An object consists of data, along with optional metadata and access controls, accessible via a name. An object resides within a bucket. There can be more than one bucket in an S3 server. Buckets which are created for the server are associated with an S3 user that is created on the S3 server.
Retrieving all fields for all S3 buckets of an SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/buckets
# The call:
curl -X GET "https://10.140.117.223/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets?fields=*&return_records=true" -H "accept: application/json"
# The response:
"records": [
    "svm": {
      "uuid": "12f3ba4c-7ae0-11e9-8c06-0050568ea123",
      "name": "vs1"
    "uuid": "527812ab-7c6d-11e9-97e8-0050568ea123",
    "name": "bucket-2",
    "volume": {
      "name": "fg_oss_1558514455",
      "uuid": "51276f5f-7c6d-11e9-97e8-0050568ea123"
    "size": 209715200,
    "logical_used_size": 157286400,
    "encryption": {
      "enabled": false
    "comment": "S3 bucket."
    "svm": {
      "name": "vs1"
    "uuid": "a8234aec-7e06-11e9-97e8-0050568ea123",
    "name": "bucket-1",
    "volume": {
      "name": "fg_oss_1558690256",
      "uuid": "a36a1ea7-7e06-11e9-97e8-0050568ea123"
    "size": 1677721600,
    "logical_used_size": 0,
    "encryption": {
      "enabled": false
    "comment": "bucket1"
"num_records": 2
Retrieving the specified bucket associated with an SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/buckets/{uuid}
# The call:
curl -X GET "https://10.140.117.223/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/527812ab-7c6d-11e9-97e8-0050568ea123" -H "accept: application/json"
# The response:
"svm": {
  "name": "vs1"
"name": "bucket-2",
"volume": {
"size": 209715200,
"encryption": {
  "enabled": false
Creating an S3 bucket for an SVM
# The API:
# The call:
curl -iku admin:netapp1! -X POST "https://10.140.117.223/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aggregates\": [ { \"name\": \"aggr5\", \"uuid\": \"12f3ba4c-7ae0-11e9-8c06-0050568ea123\" } ], \"comment\": \"S3 bucket.\", \"constituents_per_aggregate\": 1, \"name\": \"bucket-3\"}"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 24 May 2019 11:22:14 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/?name=bucket-3
Content-Length: 353
"num_records": 1,
"records": [
    "name": "bucket-3",
"job": {
  "uuid": "2e880171-7e16-11e9-bfdc-0050568ea123",
      "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea123"
Updating an S3 bucket for an SVM
# The API:
# The call:
curl -X PATCH "https://10.140.117.223/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/754389d0-7e13-11e9-bfdc-0050568ea122" -H "accept: application/json?return_records=true" -H "Content-Type: application/json" -d "{ \"comment\": \"Bucket modified.\", \"size\": 111111111111}"
# The response:
Date: Fri, 24 May 2019 11:32:27 GMT
Content-Length: 189
"job": {
  "uuid": "9beafabb-7e17-11e9-bfdc-0050568ea123",
      "href": "/api/cluster/jobs/9beafabb-7e17-11e9-bfdc-0050568ea123"
Deleting an S3 bucket for a specified SVM
# The API:
# The call:
curl -iku admin:netapp1! -X DELETE "https://10.140.117.223/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/buckets/754389d0-7e13-11e9-bfdc-0050568ea123?return_records=true" -H "accept: application/json"
# The response:
Date: Fri, 24 May 2019 11:40:17 GMT
Content-Length: 189
"job": {
  "uuid": "b3af4a54-7e18-11e9-bfdc-0050568ea123",
      "href": "/api/cluster/jobs/b3af4a54-7e18-11e9-bfdc-0050568ea123"
