REST API reference
Name-services cache setting endpoint overview
Overview
This API is used to retrieve and manage global nameservice cache settings.
Retrieving a global nameservice cache setting
The following example shows how to use the cache setting GET endpoint to retrieve the global nameservice cache setting.
# The API:
GET /api/name-services/cache/setting
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/setting" -H "accept: application/hal+json"
# The response:
"eviction_time_interval": "P2D",
"remote_fetch_enabled": true
Updating a global nameservice cache setting
The following example shows how to use the cache setting PATCH endpoint to update the global nameservice cache setting.
# The API:
PATCH /api/name-services/cache/setting
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/setting" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"eviction_time_interval\": \"PT2H\" }"
