REST API reference
Update the NIS domain and server configuration for an SVM
Updates the NIS domain and server configuration for an SVM to modify network information services settings. Use this endpoint when you need to change the domain or server details to maintain proper network service configuration.
HTTP method and endpoint
PATCH /name-services/nis/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates NIS domain and server configuration of an SVM.
Important notes
  • Both NIS domain and servers can be modified.
  • Domains and servers cannot be empty.
  • Both FQDNs and IP addresses are supported for the servers field.
  • If the domain is modified, NIS servers must also be specified.
  • IPv6 must be enabled if IPv6 family addresses are specified for the servers field.
  • vserver services name-service nis-domain modify
svm.uuid
string
path
True
Request Body
Name Type Description
binding_details
array[binding_details]
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field.
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
Example request
  "binding_details": [
      "server": "string",
      "status": {
        "code": "string",
        "message": "string"
  "bound_servers": [
    "string"
  "domain": "domainA.example.com",
  "servers": [
    "10.10.10.10",
    "example.com"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966253
IPv6 is not enabled in the cluster
2621488
Invalid SVM context
2621706
The specified SVM UUID is incorrect for the specified SVM name
3276964
NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters
3276933
A maximum of 10 NIS servers can be configured per SVM
23724109
DNS resolution failed for one or more specified servers
23724112
DNS resolution failed due to an internal error. Contact technical support if this issue persists
23724132
DNS resolution failed for all the specified servers
23724130
Cannot use an IPv6 name server address because there are no IPv6 LIFs
string
binding_status
code
string
Code corresponding to the server's binding status.
message
string
Detailed description of the server's binding status.
binding_details
server
string
Hostname/IP address of the NIS server in the domain.
status
binding_status
svm
name
string
uuid
string
nis_service
binding_details
bound_servers
array[string]
domain
string
servers
array[string]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
