REST API reference
Updates nis domain and server configuration of an svm<br/>
  • domains and servers cannot be empty
  • both fqdns and ip addresses are supported for the servers field
  • if the domain is modified, nis servers must also be specified
  • ipv6 must be enabled if ipv6 family addresses are specified for the servers field # related ontap commands
    • vserver services name-service nis-domain modify # learn more
    • [doc /name-services/nis](#docs-name-services-name-services_nis)
PATCH /name-services/nis/{svm.uuid}
Updates NIS domain and server configuration of an SVM.
Important notes
  • Both NIS domain and servers can be modified.
  • Domains and servers cannot be empty.
  • Both FQDNs and IP addresses are supported for the servers field.
  • If the domain is modified, NIS servers must also be specified.
  • IPv6 must be enabled if IPv6 family addresses are specified for the servers field.
svm.uuid
string
path
True
Request Body
Name Type Description
_links
_links
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
svm
svm
Example request
      "href": "/api/resourcelink"
  "bound_servers": [
    "string"
  "domain": "string",
  "servers": [
    "string"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966253
IPv6 is not enabled in the cluster
2621488
Invalid SVM context
2621706
The specified SVM UUID is incorrect for the specified SVM name
3276964
NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters
3276933
A maximum of 10 NIS servers can be configured per SVM
23724109
DNS resolution failed for one or more specified servers
23724112
DNS resolution failed due to an internal error. Contact technical support if this issue persists
23724132
DNS resolution failed for all the specified servers
23724130
Cannot use an IPv6 name server address because there are no IPv6 LIFs
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
nis_service
_links
_links
bound_servers
array[string]
domain
string
servers
array[string]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
