REST API reference
Update a BGP peer group for VIP
Updates a BGP peer group for VIP to change its configuration settings. Use this endpoint when you need to modify the properties of an existing BGP peer group.
HTTP method and endpoint
PATCH /network/ip/bgp/peer-groups/{uuid}
Introduced in
ONTAP 9.7
  • network bgp peer-group modify
  • network bgp peer-group rename
uuid
string
path
True
UUID of the peer group
Request Body
Name Type Description
local
local
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.
name
string
Name of the peer group
peer
peer
Information describing the router to peer with
state
string
State of the peer group
uuid
string
Example request
  "name": "bgpv4peer",
  "peer": {
    "address": "10.10.10.7"
  "state": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1967171
Internal error. Fail to access or update BGP peer group. Retry the command, if necessary.
1967188
Configuring peer address as a next hop requires an effective cluster version of 9.9.1 or later.
53281998
Failed to rename the BGP peer group because that name is already assigned to a different peer group in the IPspace.
53282006
BGP peer group could not be updated to use a peer address because the value provided is not a valid peer address. If necessary, try the command again with a routable host address.
53282007
BGP peer group could not be updated to use a peer address because the address represents a different address family to the address of the associated BGP LIF. If necessary, try the command again with a matching address family.
53282018
Failed to create BGP peer group because an existing peer group has already established a BGP session between LIF and peer address. If necessary, try the command again with a different BGP LIF or a different peer address.
53282020
To utilize the peer as the next hop, the peer IP address must be within the same subnet as the BGP LIF.
string
ipspace
Either the UUID or name is supplied on input.
name
string
IPspace name
uuid
string
IPspace UUID
ip
IP information
interface
A network interface. Either UUID or name may be supplied on input.
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
ip
IP information to create a new interface.
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
node
name
string
Name of node on which the port is located.
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name
string
node
node
uuid
string
local
peer
address
string
Peer router address
is_next_hop
boolean
Use peer address as next hop.
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
local
local
name
string
peer
peer
state
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
