Update a BGP peer group for VIP
PATCH /network/ip/bgp/peer-groups/{uuid}
Introduced In: 9.7
Updates a BGP peer group for VIP.
Related ONTAP commands
network bgp peer-group modify -
network bgp peer-group rename
uuid |
string |
path |
True |
UUID of the peer group |
Request Body
| Name | Type | Description |
local |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address. |
name |
string |
Name of the peer group |
peer |
Information describing the router to peer with |
state |
string |
State of the peer group |
uuid |
string |
Example request
"name": "bgpv4peer",
"peer": {
"address": "10.10.10.7"
"state": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1967171 |
Internal error. Fail to access or update BGP peer group. Retry the command, if necessary. |
53281998 |
Failed to rename the BGP peer group because that name is already assigned to a different peer group in the IPspace. |
53282006 |
BGP peer group could not be updated to use a peer address because the value provided is not a valid peer address. If necessary, try the command again with a routable host address. |
53282007 |
BGP peer group could not be updated to use a peer address because the address represents a different address family to the address of the associated BGP LIF. If necessary, try the command again with a matching address family. |
53282018 |
Failed to create BGP peer group because an existing peer group has already established a BGP session between LIF and peer address. If necessary, try the command again with a different BGP LIF or a different peer address. |
href |
string |
_links
ipspace
Either the UUID or name is supplied on input.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip
IP information
interface
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ip
IP information to create a new interface.
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
node
name |
string |
Name of node on which the port is located. |
port
name |
string |
node |
uuid |
string |
local
peer
address |
string |
Peer router address |
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
local |
name |
string |
peer |
state |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
