REST API reference
Update an IP subnet
Updates an IP subnet to modify its configuration, ensuring it meets your network requirements.
HTTP method and endpoint
PATCH /network/ip/subnets/{uuid}
Introduced in
ONTAP 9.11
  • network subnet modify
  • network subnet rename
  • network subnet add-ranges
  • network subnet remove-ranges
uuid
string
path
True
IP subnet UUID
Request Body
Name Type Description
available_count
integer
available_ip_ranges
array[ip_address_range]
fail_if_lifs_conflict
boolean
This action will fail if any existing interface is using an IP address in the ranges provided. Set this to false to associate any manually addressed interfaces with the subnet and allow the action to succeed.
gateway
string
The IP address of the gateway for this subnet.
ip_ranges
name
string
Subnet name
subnet
ip_info
IP information
total_count
integer
used_count
integer
uuid
string
The UUID that uniquely identifies the subnet.
Example request
  "available_count": 0,
  "available_ip_ranges": [
      "end": "10.10.10.7",
      "start": "10.10.10.7"
  "gateway": "10.1.1.1",
  "ip_ranges": [
  "name": "subnet1",
  "subnet": {
    "address": "10.10.10.7",
    "netmask": "24"
  "total_count": 0,
  "used_count": 0,
Status: 200, Ok
Status: Default
Fill error codes below. ONTAP Error Response Codes
Error Code Description
1377658
Invalid gateway for subnet in IPspace.
1377659
Subnet would overlap with existing subnet named in IPspace.
1377660
A subnet with the name already exists in the IPspace.
1377661
Subnet in IPspace cannot use subnet address because that address is already used by subnet in the same IPspace.
1377662
The IP range address is not within the subnet in IPspace.
1377663
The specified IP address range of subnet in IPspace contains an address already in use by a LIF.
1377664
The specified IP address range of subnet in IPspace contains an address already in use by the Service Processor.
1377669
The specified gateway address exists in a configured range.
1377673
The addresses provided must have the same address family.
1377674
Modifying the netmask is not supported because the subnet has one or more interfaces associated with it.
1377675
The netmask of the interface did not match the netmask of the subnet.
1377681
Cannot update LIF associations for LIF. The broadcast domain of the LIF does not match the broadcast domain of the subnet.
1966269
IPv4 Addresses must have a prefix length between 1 and 32.
1966778
IPv6 addresses must have a prefix length between 1 and 127.
53282568
The subnet.address must be specified together with subnet.netmask.
53282569
The specified subnet.netmask is not valid.
53282570
Each pair of ranges must have ip_ranges.start less than or equal to ip_ranges.end.
53282571
The ip_ranges.start and ip_ranges.end fields must have the same number of items.
53282572
PATCH partially succeeded with error.
string
ip_address_range
IP address range
end
string
IPv4 or IPv6 address
start
string
broadcast_domain
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
Broadcast domain UUID
ipspace
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.
name
string
IPspace name
uuid
string
IPspace UUID
ip_info
IP information
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ip_subnet
available_count
integer
available_ip_ranges
boolean
gateway
string
ip_ranges
name
string
Subnet name
subnet
ip_info
IP information
total_count
integer
used_count
integer
uuid
string
