Update an IP subnet
PATCH /network/ip/subnets/{uuid}
Introduced In: 9.11
Updates an IP subnet.
Related ONTAP commands
network subnet modify -
network subnet rename -
network subnet add-ranges -
network subnet remove-ranges
uuid |
string |
path |
True |
IP subnet UUID |
Request Body
| Name | Type | Description |
available_count |
integer |
available_ip_ranges |
array[ip_address_range] |
fail_if_lifs_conflict |
boolean |
This action will fail if any existing interface is using an IP address in the ranges provided. Set this to false to associate any manually addressed interfaces with the subnet and allow the action to succeed. |
gateway |
string |
The IP address of the gateway for this subnet. |
ip_ranges |
name |
string |
Subnet name |
subnet |
IP information |
total_count |
integer |
used_count |
integer |
uuid |
string |
The UUID that uniquely identifies the subnet. |
Example request
"available_count": 0,
"available_ip_ranges": [
"end": "10.10.10.7",
"start": "10.10.10.7"
"gateway": "10.1.1.1",
"ip_ranges": [
"name": "subnet1",
"subnet": {
"address": "10.10.10.7",
"netmask": "24"
"total_count": 0,
"used_count": 0,
Status: 200, Ok
Status: Default
Fill error codes below. ONTAP Error Response Codes
| Error Code | Description |
1377658 |
Invalid gateway for subnet in IPspace. |
1377659 |
Subnet would overlap with existing subnet named in IPspace. |
1377660 |
A subnet with the name already exists in the IPspace. |
1377661 |
Subnet in IPspace cannot use subnet address because that address is already used by subnet in the same IPspace. |
1377662 |
The IP range address is not within the subnet in IPspace. |
1377663 |
The specified IP address range of subnet in IPspace contains an address already in use by a LIF. |
1377664 |
The specified IP address range of subnet in IPspace contains an address already in use by the Service Processor. |
1377669 |
The specified gateway address exists in a configured range. |
1377673 |
The addresses provided must have the same address family. |
1377674 |
Modifying the netmask is not supported because the subnet has one or more interfaces associated with it. |
1377675 |
The netmask of the interface did not match the netmask of the subnet. |
1377681 |
Cannot update LIF associations for LIF. The broadcast domain of the LIF does not match the broadcast domain of the subnet. |
1966269 |
IPv4 Addresses must have a prefix length between 1 and 32. |
1966778 |
IPv6 addresses must have a prefix length between 1 and 127. |
53282568 |
The subnet.address must be specified together with subnet.netmask. |
53282569 |
The specified subnet.netmask is not valid. |
53282570 |
Each pair of ranges must have ip_ranges.start less than or equal to ip_ranges.end. |
53282571 |
The ip_ranges.start and ip_ranges.end fields must have the same number of items. |
53282572 |
PATCH partially succeeded with error. |
href |
string |
_links
ip_address_range
IP address range
end |
string |
IPv4 or IPv6 address |
start |
string |
broadcast_domain
The broadcast domain that the subnet is associated with. Either the UUID or name must be supplied on POST.
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
ipspace
The IPspace that the subnet is associated with. Either the UUID or name must be supplied on POST.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip_info
IP information
address |
string |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
ip_subnet
available_count |
integer |
boolean |
gateway |
string |
ip_ranges |
name |
string |
Subnet name |
subnet |
IP information |
total_count |
integer |
used_count |
integer |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
