REST API reference
Create an FPolicy persistent store configuration for an SVM
Configures an FPolicy persistent store for an SVM to manage event notifications in persistent mode. This setup is typically used on data SVMs to ensure consistent policy enforcement even when the store reaches capacity.
HTTP method and endpoint
POST /protocols/fpolicy/{svm.uuid}/persistent-stores
Introduced in
ONTAP 9.14
Usage notes
Creates an FPolicy persistent store configuration for a specified SVM.
Important notes:
  • FPolicy persistent store creation is allowed only on data SVMs.
  • In persistent mode, when the persistent store is full, event notifications are dropped.
Required properties
  • svm.uuid - Existing SVM in which to create the FPolicy persistent store.
  • name - Name of the FPolicy persistent store.
  • volume - Volume specified for persistent store (only FlexVol volumes of type RW are supported).
  • fpolicy persistent-store create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
name
string
The name specified for the FPolicy persistent store.
svm
svm
volume
string
The specified volume to store the events for the FPolicy persistent store.
Example request
  "name": "ps1",
  "svm": {
    "uuid": "string"
  "volume": "psvol"
Status: 201, Created
num_records
integer
Number of records
records
array[fpolicy_persistent_store]
  "num_records": 1,
  "records": [
      "name": "ps1",
      "svm": {
        "uuid": "string"
      "volume": "psvol"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
Error Code Description
9765052
Cannot create more than one persistent store per SVM
9765053
Volume mentioned does not exist in the SVM
9765068
The persistent store name is too long. It must not exceed 500 characters
2621516
This operation is only supported on a data SVM
9765069
Volume is not a Flexvol. Only FlexVols are supported for this operation.
9765071
Volume without junction-path is not supported.
9765072
Volume is not of type RW. Only volumes of type RW are supported.
svm
uuid
string
SVM UUID
The information that an FPolicy process needs in order to configure a persistent store.
name
string
svm
svm
volume
string
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
