Create an FPolicy persistent store configuration for an SVM
POST /protocols/fpolicy/{svm.uuid}/persistent-stores
Introduced In: 9.14
Creates an FPolicy Persistent Store configuration for a specified SVM.
Important notes:
FPolicy Persistent Store creation is allowed only on data SVMs.
In persistent mode, when the Persistent Store is full, event notifications are dropped.
There is flexibility to provide an existing volume or create a new volume for the persistent storage. The creation of new volume is handled internally.
For existing volumes, the snapshot policy is set to 'none' and the size is adjusted to the specified value.
Required properties
svm.uuid- Existing SVM in which to create the FPolicy Persistent Store. -
name- Name of the FPolicy Persistent Store. -
volume- Volume specified for Persistent Store (only FlexVol volumes of type RW are supported).
Optional properties
size- Size of the Persistent Store volume. -
autosize-mode- Autosize mode for the Persistent Store volume.
Related ONTAP commands
fpolicy persistent-store create
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
autosize_mode |
string |
Autosize mode for the volume. grow ‐ Volume automatically grows in response to the amount of space used. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled. |
name |
string |
The name specified for the FPolicy Persistent Store. |
size |
integer |
The size of the Persistent Store volume, in bytes. |
svm |
volume |
string |
The specified volume to store the events for the FPolicy Persistent Store. |
Example request
"autosize_mode": "string",
"name": "ps1",
"size": "100M",
"svm": {
"uuid": "string"
"volume": "psvol"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[fpolicy_persistent_store] |
"num_records": 1,
"records": [
"name": "ps1",
"size": "100M",
"svm": {
"uuid": "string"
"volume": "psvol"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
| Error Code | Description |
9765052 |
Cannot create more than one Persistent Store per SVM |
9765053 |
Volume mentioned does not exist in the SVM |
9765068 |
The Persistent Store name is too long. It must not exceed 500 characters |
2621516 |
This operation is only supported on a data SVM |
9765069 |
Volume is not a FlexVol volume. Only FlexVol volumes are supported for this operation. |
9765072 |
Volume is not of type RW. Only volumes of type RW are supported. |
9765074 |
Size is a required parameter for the creation of the Persistent Store. |
9765077 |
The SVM is not associated with any aggregates. |
524849 |
Attribute cannot be modified for the target volume because of the specified reason. |
917533 |
The target volume is not eligible for modification due to certain constraints, such as the volume being offline or currently engaged in a volume move operation. |
917826 |
Volume minimum autosize must be greater than zero. |
918647 |
The designated size exceeds the maximum available capacity of the intended volume. |
917534 |
The value specified for the field \"-size\" is too small. Update the field \"-size\" with the minimum size allowed and retry the operation. |
svm
uuid |
string |
SVM UUID |
The information that an FPolicy process needs in order to configure a Persistent Store.
autosize_mode |
string |
name |
string |
size |
integer |
svm |
volume |
string |
href |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
