Create a Kerberos realm
Creates a Kerberos realm to configure authentication and encryption for secure communication within your network environment. This setup is essential when integrating ONTAP with systems that rely on Kerberos for identity verification and secure data exchange.
HTTP method and endpoint
POST /protocols/nfs/kerberos/realms
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM on which to create the Kerberos realm. -
name- Base name for the Kerberos realm. -
kdc.vendor- Vendor of the Key Distribution Center (KDC) server for this Kerberos realm. If the configuration uses a Microsoft Active Directory domain for authentication, this field nust bemicrosoft. -
kdc.ip- IP address of the KDC server for this Kerberos realm.
Recommended optional properties
ad_server.name- Host name of the Active Directory Domain Controller (DC). This is a mandatory parameter if the kdc-vendor ismicrosoft. -
ad_server.address- IP address of the Active Directory Domain Controller (DC). This is a mandatory parameter if the kdc-vendor ismicrosoft.
Default property values
If not specified in POST, the following default property value is assigned:
kdc.port- 88 -
admin_server.port- 749 -
password_server.port- 464 -
clock_skew- 5
Related ONTAP commands
vserver nfs kerberos realm create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ad_server |
admin_server |
clock_skew |
integer |
Specifies the allowed time of clock-skew between the server and clients, in minutes. |
comment |
string |
Comment |
encryption_types |
array[string] |
kdc |
name |
string |
Kerberos realm |
password_server |
svm |
Example request
"ad_server": {
"address": "1.2.3.4",
"name": "string"
"admin_server": {
"comment": "string",
"encryption_types": [
"string"
"kdc": {
"ip": "1.2.3.4",
"port": 88,
"vendor": "string"
"name": "string",
"password_server": {
"svm": {
"name": "svm1",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response codes
| Error codes | Description |
2949121 |
Active Directory server name required. |
2949122 |
Active Directory server address required |
2949123 |
Failed to create Kerberos realm. |
2949124 |
Failed to create hosts file entry. |
3276949 |
Kerberos realm creation failed. Reason: The parameters "ad_server.name" and "ad_server.address" are only valid when "kdc.vendor" is Microsoft |
3276976 |
"realm" is a required input |
3276998 |
Only the data Vservers can own NFS Kerberos realms. |
href |
string |
_links
ad_server
address |
string |
Active Directory server IP address |
name |
string |
Active Directory server name |
admin_server
address |
string |
Admin server IP address. |
port |
integer |
Specifies the port number of admin server. |
kdc
ip |
string |
KDC IP address |
port |
integer |
KDC port |
vendor |
string |
Key Distribution Center (KDC) vendor. Following values are suported:
password_server
address |
string |
Password server IP address. |
port |
integer |
Specifies the port number of password server. |
svm
name |
string |
uuid |
string |
kerberos_realm
ad_server |
admin_server |
clock_skew |
integer |
comment |
string |
Comment |
encryption_types |
array[string] |
kdc |
name |
string |
Kerberos realm |
password_server |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
