REST API reference
Create a Kerberos realm
Creates a Kerberos realm to establish a secure authentication framework for your storage virtual machine (SVM). This setup is essential when integrating with a Key Distribution Center (KDC) for robust identity verification.
HTTP method and endpoint
POST /protocols/nfs/kerberos/realms
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM on which to create the Kerberos realm.
  • name - Base name for the Kerberos realm.
  • kdc.vendor - Vendor of the Key Distribution Center (KDC) server for this Kerberos realm. If the configuration uses a Microsoft Active Directory domain for authentication, this field nust be microsoft.
  • kdc.ip - IP address of the KDC server for this Kerberos realm.
  • ad_server.name - Host name of the Active Directory Domain Controller (DC). This is a mandatory parameter if the kdc-vendor is microsoft.
  • ad_server.address - IP address of the Active Directory Domain Controller (DC). This is a mandatory parameter if the kdc-vendor is microsoft.
Default property values
If not specified in POST, the following default property value is assigned:
  • kdc.port - 88
  • admin_server.port - 749
  • password_server.port - 464
  • clock_skew - 5
  • vserver nfs kerberos realm create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ad_server
ad_server
admin_server
admin_server
clock_skew
integer
Specifies the allowed time of clock-skew between the server and clients, in minutes.
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
password_server
password_server
svm
svm
Example request
  "ad_server": {
    "address": "1.2.3.4",
    "name": "string"
  "admin_server": {
  "comment": "string",
  "encryption_types": [
    "string"
  "kdc": {
    "ip": "1.2.3.4",
    "port": 88,
    "vendor": "string"
  "name": "string",
  "password_server": {
  "svm": {
    "name": "svm1",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response codes
Error codes Description
2949121
Active Directory server name required.
2949122
Active Directory server address required
2949123
Failed to create Kerberos realm.
2949124
Failed to create hosts file entry.
3276949
Kerberos realm creation failed. Reason: The parameters "ad_server.name" and "ad_server.address" are only valid when "kdc.vendor" is Microsoft
3276976
"realm" is a required input
3276998
Only the data Vservers can own NFS Kerberos realms.
string
ad_server
address
string
Active Directory server IP address
name
string
admin_server
address
string
Admin server IP address.
port
integer
Specifies the port number of admin server.
kdc
ip
string
KDC IP address
port
integer
KDC port
vendor
string
Key Distribution Center (KDC) vendor. Following values are supported:
  • microsoft - Microsoft Active Directory KDC
  • other - MIT Kerberos KDC or other KDC
password_server
address
string
Password server IP address.
port
integer
Specifies the port number of password server.
svm
name
string
uuid
string
kerberos_realm
ad_server
ad_server
admin_server
admin_server
clock_skew
integer
comment
string
Comment
encryption_types
array[string]
kdc
kdc
name
string
Kerberos realm
password_server
password_server
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
