Configure the AWS KMS configuration for an SVM
Configures the AWS KMS settings for a specific SVM, enabling secure management of encryption keys within AWS. Use this endpoint when setting up or modifying key management configurations to ensure your SVM can securely interact with AWS KMS.
HTTP method and endpoint
POST /security/aws-kms
Introduced in
ONTAP 9.12
Usage notes
Configures the AWS KMS configuration for the specified SVM.
Required properties
access_key_id- AWS access key ID of the user who has the appropriate access to AWS KMS. -
secret_access_key- AWS secret access key for the access key ID provided. -
svm.uuidorsvm.name- Existing SVM in which to create an AWS KMS. -
region- AWS region of the AWS KMS. -
key_id- AWS Key ID
Optional properties
service- AWS service type. -
default_domain- AWS KMS default domain. -
host- AWS KMS host's hostname. -
port- AWS KMS port. -
proxy_type- Type of proxy (http, https, etc.), if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used. -
polling_period- Polling period in minutes. -
encryption_context- Additional layer of authentication and logging.
Related ONTAP commands
security key-manager external aws enable
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
access_key_id |
string |
AWS Access Key ID of the user that has appropriate access to AWS KMS. |
amazon_reachability |
Indicates whether or not the Amazon KMS is reachable from all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
default_domain |
string |
AWS KMS default domain. |
ekmip_reachability |
array[ekmip_reachability] |
encryption_context |
string |
Additional layer of authentication and logging. |
host |
string |
AWS KMS host's hostname. |
key_id |
string |
AWS Key ID. |
polling_period |
integer |
Polling period in minutes. |
port |
integer |
AWS KMS port. |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
region |
string |
AWS region of the AWS KMS. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
secret_access_key |
string |
AWS Secret Access Key for the provided access key ID. |
service |
string |
AWS service type. |
state |
Indicates whether or not the Amazon Web Services Key Management Service (AWS KMS) key protection is available cluster-wide. |
svm |
uuid |
string |
A unique identifier for the AWS KMS. |
Example request
"access_key_id": "<id_value>",
"amazon_reachability": {
"code": "346758",
"message": "Amazon KMS is not reachable from all nodes - <reason>."
"default_domain": "domainName",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"encryption_context": "aws:fsx:fs-id=fs-0785c8beceb895999",
"host": "aws-host.host.com",
"key_id": "kmip-aws",
"polling_period": 55,
"port": 443,
"proxy_host": "proxy.eng.com",
"proxy_password": "awskze-Jwjje2-WJJPer",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"region": "us-east-1",
"scope": "string",
"secret_access_key": "<id_value>",
"service": "dynamodb.*.amazonaws.com",
"skip_verify": "",
"state": {
"code": "346758",
"message": "AWS KMS key protection is unavailable on the following nodes: node1, node2."
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"verify": "",
"verify_host": 1,
"verify_ip": ""
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[aws_kms] |
"num_records": 1,
"records": [
"code": "346758",
"code": "346758",
"node": {
"name": "node1",
"port": 443,
"proxy_port": 1234,
"scope": "string",
"skip_verify": "",
"state": {
"code": "346758",
"svm": {
"name": "svm1",
"verify": "",
"verify_host": 1,
"verify_ip": ""
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3735622 |
Certificate type not supported for create operation. |
3735645 |
You cannot specify a value for serial as it is generated automatically. |
3735657 |
Specifying \"-subtype\" when creating a certificate is not supported. |
3735664 |
Specified key size is not supported in FIPS mode. |
3735665 |
Specified hash function is not supported in FIPS mode. |
3735700 |
Specified key size is not supported. |
65536600 |
Nodes are out of quorum. |
65537518 |
Failed to find a LIF with Cluster role on node. One or more nodes may be out of quorum. |
65537900 |
Failed to enable the Amazon Web Service Key Management Service for an SVM due to an invalid secret access key. |
65537901 |
The Amazon Web Service Key Management Service (AWSKMS) cannot be enabled because all nodes in the cluster are not running a version that supports the AWSKMS feature. |
65537906 |
Failed to store the secret access key. |
65537907 |
The Amazon Web Service Key Management Service is disabled on the cluster. For further assistance, contact technical support. |
65537908 |
The Amazon Web Service Key Management Service is not supported for the admin SVM. |
65537910 |
Failed to configure Amazon Web Service Key Management Service for an SVM because a key manager has already been configured for the SVM. |
65537911 |
The Amazon Web Service Key Management Service is not supported in MetroCluster configurations. |
65537912 |
The Amazon Web Service Key Management Service cannot be configured for an SVM because one or more volume encryption keys of the SVM are stored on the admin SVM. |
65537926 |
The Amazon Web Service Key Management Service is not configured for this SVM. |
href |
string |
_links
amazon_reachability
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns a 0 if Amazon KMS is reachable from all nodes in the cluster. |
message |
string |
Error message returned when 'reachable' is false. |
reachable |
boolean |
Set to true if the Amazon KMS is reachable from all nodes of the cluster. |
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
state
cluster_state |
boolean |
Set to true when AWS KMS key protection is available on all nodes of the cluster. |
code |
string |
Code corresponding to the message. Returns a 0 if AWS KMS key protection is available on all nodes of the cluster. |
message |
string |
Error message set when cluster_state is false. |
svm
name |
string |
uuid |
string |
aws_kms
_links |
access_key_id |
string |
default_domain |
string |
string |
host |
string |
key_id |
string |
AWS Key ID. |
polling_period |
integer |
port |
integer |
AWS KMS port. |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
region |
string |
scope |
string |
secret_access_key |
string |
service |
string |
AWS service type. |
state |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
