REST API reference
Configure the AWS KMS configuration for an SVM
Configures the AWS KMS settings for a specified SVM to integrate AWS Key Management Service with your storage environment. This helps manage encryption keys for secure data transactions.
HTTP method and endpoint
POST /security/aws-kms
Introduced in
ONTAP 9.12
Usage notes
Configures the AWS KMS configuration for the specified SVM.
Required properties
  • access_key_id - AWS access key ID of the user who has the appropriate access to AWS KMS.
  • secret_access_key - AWS secret access key for the access key ID provided.
  • svm.uuid or svm.name - Existing SVM in which to create an AWS KMS.
  • region - AWS region of the AWS KMS.
  • key_id - AWS Key ID
Optional properties
  • service - AWS service type.
  • default_domain - AWS KMS default domain.
  • host - AWS KMS host's hostname.
  • port - AWS KMS port.
  • proxy_type - Type of proxy (http, https, etc.), if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • polling_period - Polling period in minutes.
  • encryption_context - Additional layer of authentication and logging.
  • security key-manager external aws enable
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
access_key_id
string
AWS Access Key ID of the user that has appropriate access to AWS KMS.
amazon_reachability
amazon_reachability
Indicates whether or not the Amazon KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
default_domain
string
ekmip_reachability
array[ekmip_reachability]
encryption_context
string
host
string
key_id
string
AWS Key ID.
polling_period
integer
port
integer
AWS KMS port.
proxy_host
string
Proxy host.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
region
string
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
secret_access_key
string
AWS Secret Access Key for the provided access key ID.
service
string
AWS service type.
state
state
Indicates whether or not the Amazon Web Services Key Management Service (AWS KMS) key protection is available cluster-wide.
svm
svm
uuid
string
A unique identifier for the AWS KMS.
Example request
  "access_key_id": "<AWS-ACCESS-KEY-ID>",
  "amazon_reachability": {
    "code": "346758",
    "message": "Amazon KMS is not reachable from all nodes - <reason>."
  "default_domain": "domainName",
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "encryption_context": "aws:fsx:fs-id=fs-0785c8beceb895999",
  "host": "aws-host.host.com",
  "key_id": "kmip-aws",
  "polling_period": 55,
  "port": 443,
  "proxy_host": "proxy.eng.com",
  "proxy_password": "awskze-Jwjje2-WJJPer",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "region": "us-east-1",
  "scope": "string",
  "secret_access_key": "<AWS-SECRET-ACCESS-KEY>",
  "service": "dynamodb.*.amazonaws.com",
  "skip_verify": "",
  "state": {
    "code": "346758",
    "message": "AWS KMS key protection is unavailable on the following nodes: node1, node2."
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "verify": "",
  "verify_host": 1,
  "verify_ip": ""
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
3735622
Certificate type not supported for create operation.
3735645
You cannot specify a value for serial as it is generated automatically.
3735657
Specifying \"-subtype\" when creating a certificate is not supported.
3735664
Specified key size is not supported in FIPS mode.
3735665
Specified hash function is not supported in FIPS mode.
3735700
Specified key size is not supported.
65536600
Nodes are out of quorum.
65537518
Failed to find a LIF with Cluster role on node. One or more nodes may be out of quorum.
65537900
Failed to enable the Amazon Web Service Key Management Service for an SVM due to an invalid secret access key.
65537901
The Amazon Web Service Key Management Service (AWSKMS) cannot be enabled because all nodes in the cluster are not running a version that supports the AWSKMS feature.
65537906
Failed to store the secret access key.
65537907
The Amazon Web Service Key Management Service is disabled on the cluster. For further assistance, contact technical support.
65537908
The Amazon Web Service Key Management Service is not supported for the admin SVM.
65537910
Failed to configure Amazon Web Service Key Management Service for an SVM because a key manager has already been configured for the SVM.
65537911
The Amazon Web Service Key Management Service is not supported in MetroCluster configurations.
65537912
The Amazon Web Service Key Management Service cannot be configured for an SVM because one or more volume encryption keys of the SVM are stored on the admin SVM.
65537926
The Amazon Web Service Key Management Service is not configured for this SVM.
65539704
The key manager cannot be configured because the SVM has NAE volumes.
string
amazon_reachability
code
string
Code corresponding to the error message. Returns a 0 if Amazon KMS is reachable from all nodes in the cluster.
message
string
Error message returned when 'reachable' is false.
reachable
boolean
Set to true if the Amazon KMS is reachable from all nodes of the cluster.
node
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
cluster_state
boolean
Set to true when AWS KMS key protection is available on all nodes of the cluster.
code
string
Code corresponding to the message. Returns a 0 if AWS KMS key protection is available on all nodes of the cluster.
message
string
Error message set when cluster_state is false.
svm
name
string
uuid
string
aws_kms
_links
_links
access_key_id
string
amazon_reachability
amazon_reachability
default_domain
string
ekmip_reachability
encryption_context
string
host
string
key_id
string
AWS Key ID.
polling_period
integer
port
integer
AWS KMS port.
proxy_host
string
Proxy host.
proxy_password
string
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
region
string
scope
string
secret_access_key
string
service
string
AWS service type.
state
state
svm
svm
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
