REST API reference
Create and send an AutoSupport message
Creates and sends an AutoSupport message using specified input parameters to facilitate monitoring and support activities.
HTTP method and endpoint
POST /support/autosupport/messages
Introduced in
ONTAP 9.6
Usage notes
Creates and sends an AutoSupport message with the provided input parameters.
Important note:
  • By default, the response is an empty object. If return_records=true is passed in the request, the response includes information about the node and the index of the invoked AutoSupport message.
  • message - Message included in the AutoSupport subject. Use this to identify the generated AutoSupport message.
Default property values
If not specified in POST, the following are the default property values:
  • type - all
  • node.name or node.uuid - Not specifying these properties invokes AutoSupport on all nodes in the cluster.
  • system node autosupport invoke
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
destination
string
Destination for the AutoSupport
error
error
Last error during delivery attempt. Empty if "status=sent-successful".
generated_on
string
Date and Time of AutoSupport generation in ISO-8601 format
index
integer
Sequence number of the AutoSupport
message
string
node
node
state
string
State of AutoSupport delivery
subject
string
Subject line for the AutoSupport
type
string
Type of AutoSupport collection to issue
uri
string
Alternate destination for the AutoSupport
Example request
  "destination": "http",
  "error": {
    "code": "53149746",
    "message": "Could not resolve host: test.com"
  "generated_on": "2019-03-25 17:30:04 -0400",
  "index": 9,
  "message": "invoked_test_autosupport_rest",
  "node": {
    "name": "node1",
  "state": "sent_successful",
  "subject": "WEEKLY_LOG",
  "type": "test",
  "uri": "https://1.2.3.4/delivery_uri"
Status: 201, Created
num_records
integer
Number of records
records
array[autosupport_message]
List of messages invoked on the node
  "num_records": 1,
  "records": [
      "error": {
        "code": "53149746",
      "index": 9,
      "node": {
        "name": "node1",
      "type": "test",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
8650866
The message parameter is not supported with performance AutoSupports
53149748
The destination URI provided for the invoked AutoSupport is invalid
error
code
integer
Error code
message
string
Error message
string
node
name
string
uuid
string
autosupport_message
destination
string
error
error
generated_on
string
index
integer
message
string
node
node
state
string
subject
string
type
string
uri
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
