Create and send an AutoSupport message
POST /support/autosupport/messages
Introduced In: 9.6
Creates and sends an AutoSupport message with the provided input parameters.
Important note:
By default, the response is an empty object. If
return_records=trueis passed in the request, the response includes information about the node and the index of the invoked AutoSupport message.
Recommended optional properties
message- Message included in the AutoSupport subject. Use this to identify the generated AutoSupport message.
Default property values
If not specified in POST, the following are the default property values:
type- all -
node.nameornode.uuid- Not specifying these properties invokes AutoSupport on all nodes in the cluster.
Related ONTAP commands
system node autosupport invoke
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
destination |
string |
Destination for the AutoSupport |
error |
Last error during delivery attempt. Empty if "status=sent-successful". |
generated_on |
string |
Date and Time of AutoSupport generation in ISO-8601 format |
index |
integer |
Sequence number of the AutoSupport |
message |
string |
Message included in the AutoSupport subject |
node |
state |
string |
State of AutoSupport delivery |
subject |
string |
Subject line for the AutoSupport |
type |
string |
Type of AutoSupport collection to issue |
uri |
string |
Alternate destination for the AutoSupport |
Example request
"destination": "http",
"error": {
"code": "53149746",
"message": "Could not resolve host: test.com"
"generated_on": "2019-03-25T17:30:04-04:00",
"index": "9",
"message": "invoked_test_autosupport_rest",
"node": {
"name": "node1",
"state": "sent_successful",
"subject": "WEEKLY_LOG",
"type": "test",
"uri": "http://1.2.3.4/delivery_uri"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": "3",
"records": [
"index": "9",
"node": {
"name": "node1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53149748 |
The destination URI provided for the invoked AutoSupport is invalid |
655294464 |
The message parameter is not supported with performance AutoSupports |
error
code |
integer |
Error code |
message |
string |
Error message |
href |
string |
_links
node
name |
string |
uuid |
string |
autosupport_message
destination |
string |
error |
generated_on |
string |
index |
integer |
message |
string |
node |
state |
string |
subject |
string |
type |
string |
uri |
string |
records
index |
integer |
Sequence number of the generated AutoSupport |
node |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
