REST API reference
Create an EMS role-based configuration for an access control role
Creates an EMS role-based configuration for an access control role to define permissions and manage event monitoring settings. Use this to control access and filter events for specific roles within your network environment.
HTTP method and endpoint
POST /support/ems/role-configs
Introduced in
ONTAP 9.13
Required properties
  • access_control_role - Uniquely identifies the access control role.
  • event_filter - Identifies the event filter.
  • limit_access_to_global_configs - Indicates whether the access control role has limited access to global EMS configurations.
  • event role-config create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
access_control_role
access_control_role
Access control role that the event filter is assigned to.
event_filter
event_filter
Event filter that is assigned to the access control role.
boolean
Indicates whether the access control has limited access to global EMS configurations.
Example request
  "access_control_role": {
    "name": "admin"
  "event_filter": {
    "name": "important-events"
Status: 201, Created
num_records
integer
Number of records
records
array[records]
  "num_records": 1,
  "records": [
        "name": "admin"
      "event_filter": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
983198
The event filter provided does not exist.
983199
The access control role provided does not exist.
string
access_control_role
name
string
Role name
event_filter
name
string
ems_role_config
access_control_role
access_control_role
event_filter
event_filter
boolean
records
access_control_role
access_control_role
event_filter
event_filter
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
