Create an EMS role-based configuration for an access control role
POST /support/ems/role-configs
Introduced In: 9.13
Creates an EMS role-based configuration for an access control role.
Required properties
access_control_role
- Uniquely identifies the access control role.
Recommended optional properties
event_filter
- Identifies the event filter. -
limit_access_to_global_configs
- Indicates whether the access control role has limited access to global EMS configurations.
Related ONTAP commands
event role-config create
Name | Type | In | Required | Description |
return_records |
boolean |
query |
False |
Request Body
Name | Type | Description |
access_control_role |
Access control role that the event filter is assigned to. |
event_filter |
Event filter that is assigned to the access control role. |
limit_access_to_global_configs |
boolean |
Indicates whether the access control has limited access to global EMS configurations. |
Example request
"access_control_role": {
"name": "admin"
"event_filter": {
"name": "important-events"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": 1,
"records": [
"name": "admin"
"event_filter": {
Headers
Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
Error Code | Description |
983198 |
The event filter provided does not exist. |
983199 |
The access control role provided does not exist. |
href |
string |
_links
access_control_role
name |
string |
Role name |
event_filter
name |
string |
ems_role_config
event_filter |
boolean |
records
event_filter |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
