Protocols fpolicy svm.uuid persistent-stores endpoint overview
Overview
The FPolicy persistent store feature enables the configuration of a persistent store. This includes:
setting up a store to retain event notifications
specifying the volume created for FPolicy persistent store
Each SVM can only have one persistent store. The same persistent store can be used by multiple policies within the same SVM. Once a persistent store is created, it can be utilized in the FPolicy policy configuration for the async and non-mandatory engine.
Creating an FPolicy persistent store with all required parameters
# The API:
POST /protocols/fpolicy/{svm.uuid}/persistent-stores
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores?return_records=true" -H "accept: application/json" -d "{\"name\": \"ps1\", \"volume\": \"psvol\" }"
# The response:
"num_records": 1,
"records": [
"name": "ps1",
"volume": "psvol",
Creating an FPolicy persistent store with the minimum required fields
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{\"name\": \"ps1\", \"volume\": \"psvol\" }"
# The response:
"num_records": 1,
"records": [
"name": "ps1",
"volume": "psvol",
Retrieving an FPolicy persistent store configuration for a specific SVM
# The API:
GET /protocols/fpolicy/{svm.uuid}/persistent-stores
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"name": "ps1"
"num_records": 1
Retrieving a specific FPolicy persistent store configuration for a specific SVM
# The API:
GET /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"svm": {
"uuid": "4f643fb4-fd21-11e8-ae49-0050568e2c1e"
"name": "ps1",
"volume": "psvol",
Updating an FPolicy persistent store for an SVM
# The API:
PATCH /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"volume\": \"psvol\" }"
Deleting a specific FPolicy persistent store configuration for a specific SVM
# The API:
DELETE /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy" -H "accept: application/json"
