REST API reference
Protocols NFS connected-client-settings endpoint overview
Overview
This cluster-wide API is used to set the maximum cache idle time (client_retention_interval) for the connected-clients cache. If a client connected to NFS server is idle for longer than than the maximum cache idle time, the entry will be removed. The update_interval value will change when the client_retention_interval is changed. The update interval represents the interval between the cleaning happens. If the value of client_retention_interval is set to 60hrs the connected client entry will stay there for 60 hours and after that it will get removed. If the value of update_interval is 8 hours then the cache will be refreshed once every 8 hours.
Example
Retrieves connected-client cache settings information
# The API:
GET /api/protocols/nfs/connected-client-settings
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/nfs/connected-client-settings?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"client_retention_interval": "P7D",
"update_interval": "PT8H"
Updating connected-client cache settings
# The API:
PATCH /api/protocols/nfs/connected-client-settings
# The call:
curl -d "@test_cache_settings_patch.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/connected-client-settings"
test_cache_settings_patch.txt(body):
