REST API reference
Protocols S3 services svm.uuid policies endpoint overview
Overview
An S3 policy is an object that when associated with a resource, defines their permissions. Buckets and objects are defined as resources. Policies are used to manage access to these resources.
Retrieving all fields for all S3 policies of an SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/policies:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"num_records": 2,
"records": [
    "comment": "S3 policy.",
    "name": "Policy1",
    "statements": [
        "actions": [
        "effect": "allow",
        "index": 0,
        "resources": [
          "bucket1",
          "bucket1/*"
        "sid": "FullAccessToBucket1"
        "actions": [
          "DeleteObject"
        "effect": "deny",
        "index": 1,
        "resources": [
        "sid": "DenyDeleteObjectAccessToAllResources"
    "svm": {
      "name": "svm1",
    "comment": "S3 policy 2.",
    "name": "Policy2",
    "statements": [
        "actions": [
          "GetObject"
        "effect": "allow",
        "index": 3,
        "resources": [
        "sid": "AllowGetObjectAccessToAllResources"
        "actions": [
        "effect": "deny",
        "index": 3,
        "resources": [
        "sid": "DenyAccessToAllResources"
    "svm": {
      "name": "svm1",
Retrieving the specified policy in the SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/policies/{name}:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies/Policy1?fields=*" -H "accept: application/json"
# The response:
"name": "Policy1",
"statements": [
    "actions": [
      "GetObject",
      "PutObject",
      "DeleteObject",
      "ListBucket",
      "ListMyBuckets",
      "ListBucketMultipartUploads",
      "ListMultipartUploadParts",
      "GetObjectTagging",
      "PutObjectTagging",
      "DeleteObjectTagging",
      "GetBucketVersioning",
      "PutBucketVersioning"
    "effect": "deny",
    "index": 0,
    "resources": [
"svm": {
  "name": "svm1",
Creating an S3 policy for an SVM
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies?return_records=true" -H "accept: application/json" -H "authorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 policy.\", \"name\": \"Policy1\", \"statements\": [ { \"actions\": [ \"ListBucket\", \"ListMyBuckets\", \"CreateBucket\", \"DeleteBucket\" ], \"effect\": \"allow\", \"resources\": [ \"*\" ], \"sid\": \"AllowListAccessToAllResources\" } ]}"
# The response:
HTTP/1.1 202 Accepted
Date: Mon, 16 Mar 2020 11:32:27 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 289
"num_records": 1,
"records": [
    "name": "Policy1",
    "statements": [
        "actions": [
          "ListBucket",
          "ListMyBuckets"
        "effect": "allow",
        "index": 5,
        "resources": [
        "sid": "AllowListAccessToAllResources"
    "svm": {
      "name": "svm1",
Updating an S3 policy for an SVM
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies/Policy1" -H "accept: application/json" -H "authorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"comment\": \"S3 policy.\", \"statements\": [ { \"actions\": [ \"GetObject\", \"PutObject\", \"DeleteObject\", \"ListBucket\", \"ListMyBuckets\", \"CreateBucket\", \"DeleteBucket\"], \"effect\": \"allow\", \"resources\": [ \"bucket1\", \"bucket1/*\" ], \"sid\": \"FullAccessToAllResources\" } ]}"
# The response:
Content-Length: 189
Deleting an S3 policy for a specified SVM
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/s3/services/12f3ba4c-7ae0-11e9-8c06-0050568ea123/policies/Policy1" -H "accept: application/json"
# The response:
Content-Length: 189
