REST API reference
Protocols san iscsi credentials endpoint overview
Overview
An iSCSI credentials object defines authentication credentials to be used between an initiator and ONTAP. It identifies an authentication type, user names, and passwords that must be used to authenticate a specific initiator.
The iSCSI credentials REST API allows you to create, update, delete, and discover iSCSI credentials.
How iSCSI authentication works
An iSCSI credentials object defines the authentication credentials to be used between an initiator and ONTAP. While establishing an iSCSI connection, the initiator sends a login request to ONTAP to begin an iSCSI session. ONTAP then either permits or denies the login request, or determines that a login is not required.
For an initiator, you can specify an authentication type, user names and passwords, and a whitelist of optional network addresses from which the initiator is allowed to connect.
iSCSI authentication methods
  • Challenge-Handshake Authentication Protocol (CHAP) - The initiator logs in using a CHAP user name and password. There are two types of CHAP user names and passwords:
    • Inbound - ONTAP authenticates the initiator. Inbound settings are required if you are using CHAP authentication.
    • Outbound - These are optional credentials to enable the initiator to authenticate ONTAP. You can use credentials only if inbound credentials are also being used.
  • deny - The initiator is denied access to ONTAP.
  • none - ONTAP does not require authentication for the initiator. The CHAP inbound/outbound password can be any valid string or an even number of valid hexadecimal digits preceded by '0X' or '0x'.
Initiator address list
The initiator address list is a way to specify valid IP addresses from which the initiator is allowed to connect. If the list is specified and the source address of an iSCSI connection is not in the list, the connection is rejected. Initiator addresses can be specified in either IPv4 or IPv6 format and in one of two forms:
  • Range
  "start": "192.168.0.0",
  "end": "192.168.0.255"
  • Mask
  "address": "192.168.0.0",
  "netmask": "24"
Initiator "default"
The default iSCSI authentication definition is created when the iSCSI service is created. An iSCSI credentials object with default as the initiator name identifies the default authentication for an SVM. The default credentials are used for any initiator that does not have specific iSCSI credentials. The default iSCSI authentication method is none, but can be changed to deny or CHAP. The default credentials object does not support an initiator address list.
Creating iSCSI credentials requiring no authentication
# The API:
POST /api/protocols/san/iscsi/credentials
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/iscsi/credentials' -H 'Accept: application/hal+json' -d '{ "svm": { "name": "svm1" }, "initiator": "iqn.1992-08.com.netapp:initiator1", "authentication_type": "none" }'
Creating iSCSI credentials using CHAP inbound authentication
# The API:
# The call:
curl -X POST 'https://<mgmt-ip>/api/protocols/san/iscsi/credentials' -H 'Accept: application/hal+json' -d '{ "svm": { "name": "svm1" }, "initiator": "iqn.1992-08.com.netapp:initiator2", "authentication_type": "CHAP", "chap": { "inbound": { "user": "user1", "password": "password1" } } }'
Retrieving all properties of all iSCSI credentials
The fields query parameter is used to request all iSCSI credentials properties.
Passwords are not included in the GET output.
# The API:
GET /api/protocols/san/iscsi/credentials
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/iscsi/credentials?fields=*' -H 'Accept: application/hal+json'
# The response:
"records": [
    "svm": {
      "uuid": "19d04b8e-94d7-11e8-8370-005056b48fd2",
      "name": "svm1",
          "href": "/api/svm/svms/19d04b8e-94d7-11e8-8370-005056b48fd2"
    "initiator": "default",
    "authentication_type": "none",
        "href": "/api/protocols/san/iscsi/credentials/19d04b8e-94d7-11e8-8370-005056b48fd2/default"
    "svm": {
      "name": "svm1",
        "href": "/api/protocols/san/iscsi/credentials/19d04b8e-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator1"
    "svm": {
      "name": "svm1",
    "authentication_type": "chap",
    "chap": {
      "inbound": {
        "user": "user1"
        "href": "/api/protocols/san/iscsi/credentials/19d04b8e-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator2"
    "svm": {
      "uuid": "25f617cf-94d7-11e8-8370-005056b48fd2",
      "name": "svm2",
          "href": "/api/svm/svms/25f617cf-94d7-11e8-8370-005056b48fd2"
        "href": "/api/protocols/san/iscsi/credentials/25f617cf-94d7-11e8-8370-005056b48fd2/default"
    "svm": {
      "name": "svm2",
        "href": "/api/protocols/san/iscsi/credentials/25f617cf-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator2"
    "svm": {
      "name": "svm2",
    "initiator": "iqn.1992-08.com.netapp:initiator3",
    "authentication_type": "deny",
        "href": "/api/protocols/san/iscsi/credentials/25f617cf-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator3"
"num_records": 6,
    "href": "/api/protocols/san/iscsi/credentials?fields=*"
Retrieving specific iSCSI credentials
# The API:
GET /api/protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
# The call:
curl -X GET 'https://<mgmt-ip>/api/protocols/san/iscsi/credentials/25f617cf-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator2' -H 'Accept: application/hal+json'
# The response:
"svm": {
  "name": "svm2",
"chap": {
  "inbound": {
    "user": "user1"
Updating the authentication type of iSCSI credentials
# The API:
PATCH /api/protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/protocols/san/iscsi/credentials/25f617cf-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator2' -H 'Accept: application/hal+json' -d '{ "authentication_type": "chap", "chap": { "inbound": { "user": "user1", "password": "password1" } } }'
Updating the initiator address list of iSCSI credentials
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/protocols/san/iscsi/credentials/25f617cf-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator2' -H 'Accept: application/hal+json' -d '{ "initiator_address": { "ranges": [ { "start": "192.168.0.0", "end": "192.168.255.255" } ] } }'
Deleting iSCSI credentials
# The API:
DELETE /api/protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
# The call:
curl -X DELETE 'https://<mgmt-ip>/api/protocols/san/iscsi/credentials/25f617cf-94d7-11e8-8370-005056b48fd2/iqn.1992-08.com.netapp:initiator2' -H 'Accept: application/hal+json'
