REST API reference
Support coredump coredumps endpoint overview
Overview
The core dump GET API retrieves all of the core dumps on the cluster or a node. The core dump DELETE API deletes a specified core dump. Some fields are only populated for core dump type "kernel". Refer to the model for further information. Fields will not be displayed if they are not populated. A core can be deleted even if the core is in the process of being saved.
1) Retrieving a list of core dumps from the cluster
The following example returns a list of core dumps on the cluster:
# The API:
/api/support/coredump/coredumps
# The call:
curl -X GET "https://<mgmt-ip>/api/support/coredump/coredumps" -H "accept: application/hal+json"
# The response:
"records": [
    "node": {
      "uuid": "227683c1-e9c7-11eb-b995-005056bbbfb3",
      "name": "node2",
          "href": "/api/cluster/nodes/227683c1-e9c7-11eb-b995-005056bbbfb3"
    "type": "kernel",
    "name": "core.4136886422.2021-07-21.20_20_53.nz",
        "href": "/api/support/coredump/coredumps/227683c1-e9c7-11eb-b995-005056bbbfb3/core.4136886422.2021-07-21.20_20_53.nz"
    "node": {
      "name": "node2",
    "type": "application",
    "name": "mlogd.968.4136886422.2021-07-22.01_10_01.ucore.bz2",
        "href": "/api/support/coredump/coredumps/227683c1-e9c7-11eb-b995-005056bbbfb3/mlogd.968.4136886422.2021-07-22.01_10_01.ucore.bz2"
    "node": {
      "uuid": "d583d44e-e9c6-11eb-a270-005056bb47f9",
      "name": "node1",
          "href": "/api/cluster/nodes/d583d44e-e9c6-11eb-a270-005056bb47f9"
    "type": "kernel",
    "name": "core.4136886421.2021-07-21.17_57_02.nz",
        "href": "/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/core.4136886421.2021-07-21.17_57_02.nz"
    "node": {
      "name": "node1",
    "name": "mlogd.979.4136886421.2021-07-22.01_11_37.ucore.bz2",
        "href": "/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/mlogd.979.4136886421.2021-07-22.01_11_37.ucore.bz2"
"num_records": 4,
    "href": "/api/support/coredump/coredumps"
2) Retrieving a specific core dump
The following example returns the requested core dump. If there is no core dump with the requested node UUID and name, an error is returned.
# The API:
/api/support/coredump/coredumps/{node.uuid}/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/core.4136886421.2021-07-21.17_57_02.nz" -H "accept: application/hal+json"
# The response:
"node": {
  "name": "node1",
"type": "kernel",
"panic_time": "2021-07-21T13:57:02-04:00",
"size": 945111148,
"md5_data_chksum": "611a6fa50d230a1af402f3724ab320af",
"is_saved": true,
3) Deleting a core dump
The following example deletes the requested core dump. If there is no core dump with the requested node UUID and name to delete, an error is returned.
# The API:
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/coredump/coredumps/d583d44e-e9c6-11eb-a270-005056bb47f9/mlogd.979.4136886421.2021-07-22.01_11_37.ucore.bz2" -H "accept: application/hal+json"
# The response header:
HTTP/1.1 200 OK
Date: Thu, 22 Jul 2021 01:32:24 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 3
Content-Type: application/hal+json
