SVM peer-permissions endpoint overview
Managing SVM peer permissions
A cluster administrator can provide permissions for use during intercluster SVM peer relationship creation. Once this permission exists for a local SVM and peer cluster combination on a local cluster, no explicit SVM peer accept (or REST PATCH) API is required for any incoming SVM peer relationship creation requests from a remote cluster for that local SVM. Peer relationship directly changes the state to peered on both clusters. Use an SVM name as "*" to create permissions that apply to all local SVMs.
SVM peer permission APIs
The following APIs are used to manage SVM peer permissions:
GET /api/svm/peer-permissions
POST /api/svm/peer-permissions
GET /api/svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
PATCH /api/svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
DELETE /api/svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
