REST API reference
ONTAP REST API Cluster chassis endpoints
Overview
You can use the chassis GET API to retrieve all of the chassis information in the cluster.
Retrieving a list of chassis from the cluster
The following example shows the response with a list of chassis in the cluster:
# The API:
/api/cluster/chassis
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/chassis" -H "accept: application/hal+json"
# The response:
"records": [
    "id": "021352005981",
        "href": "/api/cluster/chassis/021352005981"
"num_records": 1,
    "href": "/api/cluster/chassis"
Retrieving a specific chassis from the cluster
The following example shows the response of the requested chassis. If there is no chassis with the requested ID, an error is returned.
# The API:
/api/cluster/chassis/{id}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/chassis/021352005981" -H "accept: application/hal+json"
# The response:
"state": "ok",
"nodes": [
    "name": "node-1",
    "uuid": "6ede364b-c3d0-11e8-a86a-00a098567f31",
    "position": "top",
    "usbs": {
      "supported": true,
      "enabled": true,
      "ports": [
          "connected": false
    "pcis": {
      "cards": [
          "slot": "0",
          "device": "Gigabit Ethernet I210",
          "info": "\t  e0M MAC Address:    d0:39:ea:3f:06:2b (auto-1000t-fd-up) \n\t  e0S MAC Address:    d0:39:ea:3f:06:2c (auto-1000t-fd-up) \n\t  Device Type:        1533\n\t  Firmware Version:   3.25-0.0 0x800005D1\n"
          "slot": "0",
          "device": "Intel Lewisburg series chipset SATA Controller",
          "info": "\t  Additional Info: 0 (0xaaf00000)   \n\t  SHM2S86Q120GLM22NP FW1146 114473MB 512B/sect (SPG190108HJ)  \n"
        "href": "/api/cluster/nodes/6ede364b-c3d0-11e8-a86a-00a098567f31"
"frus": [
    "id": "PSU2",
    "type": "psu",
    "state": "ok"
    "id": "PSU1",
    "type": "psu",
    "state": "ok"
    "id": "Fan2",
    "type": "fan",
    "state": "ok"
    "id": "Fan3",
    "type": "fan",
    "state": "ok"
    "id": "Fan1",
    "type": "fan",
    "state": "ok"
