Cluster chassis endpoint overview
Overview
You can use the chassis GET API to retrieve all of the chassis information in the cluster.
Retrieving a list of chassis from the cluster
The following example shows the response with a list of chassis in the cluster:
# The API: /api/cluster/chassis # The call: curl -X GET "https://<mgmt-ip>/api/cluster/chassis" -H "accept: application/hal+json" # The response: { "records": [ { "id": "021352005981", "_links": { "self": { "href": "/api/cluster/chassis/021352005981" } } }, ], "num_records": 1, "_links": { "self": { "href": "/api/cluster/chassis" } } }
Retrieving a specific chassis from the cluster
The following example shows the response of the requested chassis. If there is no chassis with the requested ID, an error is returned.
# The API: /api/cluster/chassis/{id} # The call: curl -X GET "https://<mgmt-ip>/api/cluster/chassis/021352005981" -H "accept: application/hal+json" # The response: { "id": "021352005981", "state": "ok", "nodes": [ { "name": "node-1", "uuid": "6ede364b-c3d0-11e8-a86a-00a098567f31", "position": "top", "usbs": { "supported": true, "enabled": true, "ports": [ { "connected": false } ] }, "pcis": { "cards": [ { "slot": "0", "device": "Gigabit Ethernet I210", "info": "\t e0M MAC Address: d0:39:ea:3f:06:2b (auto-1000t-fd-up) \n\t e0S MAC Address: d0:39:ea:3f:06:2c (auto-1000t-fd-up) \n\t Device Type: 1533\n\t Firmware Version: 3.25-0.0 0x800005D1\n" }, { "slot": "0", "device": "Intel Lewisburg series chipset SATA Controller", "info": "\t Additional Info: 0 (0xaaf00000) \n\t SHM2S86Q120GLM22NP FW1146 114473MB 512B/sect (SPG190108HJ) \n" } ] }, "_links": { "self": { "href": "/api/cluster/nodes/6ede364b-c3d0-11e8-a86a-00a098567f31" } } } ], "frus": [ { "id": "PSU2", "type": "psu", "state": "ok" }, { "id": "PSU1", "type": "psu", "state": "ok" }, { "id": "Fan2", "type": "fan", "state": "ok" }, { "id": "Fan3", "type": "fan", "state": "ok" }, { "id": "Fan1", "type": "fan", "state": "ok" } ], "_links": { "self": { "href": "/api/cluster/chassis/021352005981" } } }
