Cluster chassis endpoint overview
Overview
You can use the chassis GET API to retrieve all of the chassis information in the cluster.
Retrieving a list of chassis from the cluster
The following example shows the response with a list of chassis in the cluster:
# The API:
/api/cluster/chassis
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/chassis" -H "accept: application/hal+json"
# The response:
"records": [
"id": "021352005981",
"href": "/api/cluster/chassis/021352005981"
"num_records": 1,
"href": "/api/cluster/chassis"
Retrieving a specific chassis from the cluster
The following example shows the response of the requested chassis. If there is no chassis with the requested ID, an error is returned.
# The API:
/api/cluster/chassis/{id}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/chassis/021352005981" -H "accept: application/hal+json"
# The response:
"state": "ok",
"nodes": [
"name": "node-1",
"uuid": "6ede364b-c3d0-11e8-a86a-00a098567f31",
"href": "/api/cluster/nodes/6ede364b-c3d0-11e8-a86a-00a098567f31"
"frus": [
"id": "PSU2",
"type": "psu",
"state": "ok"
"id": "PSU1",
"type": "psu",
"state": "ok"
"id": "Fan2",
"type": "fan",
"state": "ok"
"id": "Fan3",
"type": "fan",
"state": "ok"
"id": "Fan1",
"type": "fan",
"state": "ok"
