REST API reference
Delete an OAuth 2.0 configuration
Deletes an existing OAuth 2.0 configuration by specifying its name. Use this endpoint to manage and remove configurations no longer needed for your authentication setup.
HTTP method and endpoint
DELETE /security/authentication/cluster/oauth2/clients/{name}
Introduced in
ONTAP 9.14
Usage notes
Deletes the OAuth 2.0 configuration with the specified name.
Required properties
  • config_name
  • security oauth2 client delete
name
string
path
True
OAuth 2.0 configuration name.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
203816995
OAuth 2.0 must be disabled before the configuration can be removed.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
