Delete an OAuth 2.0 configuration
DELETE /security/authentication/cluster/oauth2/clients/{name}
Introduced In: 9.14
Deletes the OAuth 2.0 configuration with the specified name.
Required properties
config_name
Related ONTAP commands
security oauth2 client delete
name  |
string  |
path  |
True  |
OAuth 2.0 configuration name.  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
203816995  |
OAuth 2.0 must be disabled before the configuration can be removed.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
