REST API reference
Delete a Duo profile for an SVM or cluster
Deletes the Duo profile associated with an SVM or cluster, removing its two-factor authentication configuration.
HTTP method and endpoint
DELETE /security/authentication/duo/profiles/{owner.uuid}
Introduced in
ONTAP 9.14
Usage notes
Deletes the Duo profile of the SVM or cluster.
  • security login duo delete
owner.uuid
string
path
True
Account owner UUID.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
