Delete a Duo profile for an SVM or cluster
DELETE /security/authentication/duo/profiles/{owner.uuid}
Introduced In: 9.14
Deletes the Duo profile of the SVM or cluster.
Related ONTAP commands
security login duo delete
Name | Type | In | Required | Description |
owner.uuid |
string |
path |
True |
Account owner UUID. |
Status: 200, Ok
Status: Default, Error
Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
