Delete an inactive keystore configuration
Deletes an inactive keystore configuration to remove unused or obsolete security keys from your system.
HTTP method and endpoint
DELETE /security/key-stores/{uuid}
Introduced in
ONTAP 9.14
Related ONTAP commands
security key-manager keystore delete
uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262155 |
This operation requires an effective cluster version of 9.14.0 or later. |
65538905 |
The keystore configuration is currently enabled and cannot be deleted. |
65538907 |
The method is not yet supported for deleting the given UUID's type of configuration. |
65538908 |
The specified keystore configuration UUID either does not exist or corresponds to a keystore configuration that is not supported by this operation. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
