REST API reference
Delete an inactive keystore configuration
DELETE /security/key-stores/{uuid}
Introduced In: 9.14
Deletes an inactive keystore configuration.
  • security key-manager keystore delete
uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262155
This operation requires an effective cluster version of 9.14.0 or later.
65538905
The keystore configuration is currently enabled and cannot be deleted.
65538907
The method is not yet supported for deleting the given UUID's type of configuration.
65538908
The specified keystore configuration UUID either does not exist or corresponds to a keystore configuration that is not supported by this operation.
65539521
An effective cluster version of ONTAP 9.16.1 or later is required to delete an inactive key manager on the admin SVM.
65539522
This command does not support disabling key manager configurations with the specified keystore type on the admin SVM.
65539593
Cannot delete an inactive key manager configuration while the keystore is in the switching state.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
